any ideas?
Old 28-04-2006 | 07:43 PM
BM08's Avatar
BM08
Default any ideas?
How to stop this?
Thought about cable ties or something?
If you cant see its the throttle cable touching the top of the cover and its making indentations on it and it WILL NOT bend any other way without springing back into position
Old 28-04-2006 | 08:16 PM
Damo V's Avatar
Damo V
wouldnt worry
Old 28-04-2006 | 08:17 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Take it off
BM08's Avatar
BM08
I know but its making dirty great marks and its annoying
Old 28-04-2006 | 08:33 PM
Damo V's Avatar
Damo V
What even dirtier marks than the rest of the engine bay?
Old 28-04-2006 | 09:22 PM
BM08's Avatar
BM08
You cheeky sod
Im not no bufty, never clean under the bonnet and i think that cable making a permenant dent in the rocker cover is abit more to worry about than abit of muck/grime that would clean off with abit of elbow grease!?
If you cant answer my question then dont post, its not rocket science
Old 28-04-2006 | 09:25 PM
Eagle's Avatar
Eagle
Super Moderator
put some double sided foam sticky pads between the cable and rocker cover ... cut it so its the same width as the cable and it should stay put...
Old 28-04-2006 | 09:26 PM
Jim Galbally's Avatar
Jim Galbally
damo's got a point man, its already minging so it wont matter
Old 28-04-2006 | 09:42 PM
AndyRST's Avatar
AndyRST
You cheeky sod
The cable wont dent your rocker cover, its only resting on the top of it, not being pressed into the rocker cover
Old 28-04-2006 | 09:45 PM
tonyk's Avatar
tonyk
I wouldnt think the plastic shielding would damage a metal rocker cover, why not a bit of masking tape or insulation tape round it.
Old 28-04-2006 | 09:55 PM
BM08's Avatar
BM08
It has mate, as i said before its made an indentation but i guess if its already made a dent i may aswell leave it there just didnt want it wearing the cable away or something because obviously the rocker cover gets very hot.
Old 28-04-2006 | 09:59 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
You'll probably find that "dent" is supposed to be there So the cable just rests in it
Old 28-04-2006 | 10:04 PM
Jayen4's Avatar
Jayen4
Where the cable passes over that bolt on the side of the cam carrier housing........ Why don't you make up a little bracket,to hold the cable,so that it sits just above the cam cover ??
Something like a plug lead tidy bracket,from a breaker,could be modified to do the job !! O.K. ??
Old 28-04-2006 | 10:09 PM
BM08's Avatar
BM08
good thinking batman
Old 28-04-2006 | 10:36 PM
Jayen4's Avatar
Jayen4
Glad to be of service !!
By the way........I want a pic,when you've done the mod,to see if I approve,o.k?? LOL !!
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
Brickhouse
14
03-10-2015 08:28 PM
Fezman1
02-10-2015 02:22 PM
Orion_Gav
29-09-2015 05:50 PM
rogerxr3i
13-09-2015 07:56 PM
