Adhering bodykits on S2
Old 04-08-2004, 07:47 AM
zvhturbo
zvhturbo's Avatar
Default Adhering bodykits on S2
Morning chaps,
I've started to put the body kit back on my S2 using Sikaflex Proffesional body kit adhesive (white)
However around the edges there is a small seem of this mastic and it gets dirty really easy and holds the dirt.
Is there a product you have used to fill this gap to prevent the dirt.
I have found one product, its a PVCU window joint adhesive and sets solid like plastic, however i'm worried it may crack.
Thanks
Matt.
Old 04-08-2004, 10:05 AM
Tony Turbo
www.ctuceilings.co.uk
Tony Turbo's Avatar
You have PM, but then you knew that because of the little window that popped up when you pressed refresh LOL
adamS2RST
adamS2RST's Avatar
Old 04-08-2004, 10:26 AM
CabrioTurbo
CabrioTurbo's Avatar
use propper rivvets mine is rivveted onto my cab and hasnt moved yet! (except when someone hit the car of my car
Old 04-08-2004, 10:27 AM
zvhturbo
zvhturbo's Avatar
Not if i've got the pop up turned off
Cheers mate.
Matt.
Old 04-08-2004, 10:29 AM
zvhturbo
zvhturbo's Avatar
I've used all genuine ford rivets and bolts etc but the seam between the bodykit and car panels collects dirt so i used white bodykit adhesive, but the adhesive colects dirt as well, not good on a white car.
Old 04-08-2004, 10:36 AM
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
My bodyshop bloke left that area unsealented(?) thus to prevent the sealent around the kit cracking and/or collecting dirt.
It dosen't look as tidy as i like, but i wont have the further worry of it cracking, falling out or getting dirty.
What did Damo do with yours TT?
Old 04-08-2004, 10:43 AM
zvhturbo
zvhturbo's Avatar
The Sikaflex is umbelievably flexible so i'm sure that won't crack, fingers crossed.
Its just the dam stuff collect dirt.
I may have to run a really thin layer of paint over it.
Old 04-08-2004, 10:52 AM
MWF
MWF's Avatar
The window joint stuff wont crack.
Old 04-08-2004, 11:10 AM
Tony Turbo
Tony Turbo's Avatar
Not really... truth is... I don't know
Old 04-08-2004, 11:16 AM
starturbo
starturbo's Avatar
If you know any aircraft fitters they could get you some PRC.its used for sealing fuel tanks internally and is totally flexable.Its brown though and wont attract anything when it sets.only prob is that it comes in brown or silver.
Old 04-08-2004, 11:40 AM
zvhturbo
zvhturbo's Avatar
http://www.screwfix.com/app/sfd/sea/...1&cd=1&x=9&y=7
Thats the stuff i'm talking about.
Will this stuff crack?
I've ordered some so will test it out first.
Matt.
IainRS1700T
25-09-2015 06:44 AM
FlashRS
14-09-2015 12:36 PM
Quick Reply: Adhering bodykits on S2
