Rev Counter!!?
Old Apr 27, 2006 | 07:42 AM
Mark 3D's Avatar
Mark 3D
Moderator
Default Rev Counter!!?
I have just fitted a new set of clocks in my 3 door and the rev counter doesent work
Its getting power to it etc etc
I was just wondering how a rev counter actually works seeing as theres no cable attched to it as such!!?
Cheers,
Mark
Old Apr 27, 2006 | 07:44 AM
Stu @ M Developments's Avatar
PassionFords Creator
The rev counter is supplied with a signal from the green wire in the plug to teh clocks. Sounds like you have bought a set of dead clocks pal.
Old Apr 27, 2006 | 07:49 AM
Mark 3D's Avatar
Mark 3D
Moderator
Thanks for the advice Stu, my next question was going to be which wire from the loom did i need to check but didnt think anyone would be techy enough to know!!!! lol
Old Apr 27, 2006 | 08:45 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's basicly run off of the coil
if everything is plugged in properly the only reason it's not working will be duff clocks as stu says
unless someone with a bit more info can tell what readings you would be looking for with a multimeter to see if there wasn't a break in the wire?
Old Apr 27, 2006 | 09:56 AM
RS500/364's Avatar
RS500/364
Dry joint inside the clock i had some resoldered and sorted
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
