Slowpokes new brakes - amazing :D
Team HOTHOT!
Today, after weeks of me designing brackets and creasing ISO drawings for them, and Matt machining them, we fitted his new brakes
Here are a few pictures of them.
The old ones - a Hi-spec 300mm conversion
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/Old.jpg)
The new bracket fitted - made out of A2 Stainless Billet
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/Bracket.jpg)
The new caliper fitted - my god its HUGE
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/New.jpg)
And finally, a few with the wheels fitted
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/Fitted1.jpg)
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/Fitted.jpg)
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/Fitted3.jpg)
![](https://i6.photobucket.com/albums/y241/Graceland1/Slowpoke/Fitted4.jpg)
Big thanks to matt for allowing me to prototype this big brake kit on his car (at his expence) - I'm sure that once the pads are bedded in, the car will be doing rollovers and endo's on the motorway
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Team HOTHOT!
PS People - the pictures don't give a true size of the calipers - they are approx 14" tall, and the pistons are 2" diameter each, and each caliper has 4 pistons
some serious stopping power
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Team HOTHOT!
Some poor Range Rover has lost its calipers
But some happy Matt is now chuffed to bits, I'm even more happy as it was a bit of a personal mission to make these badboys fit
How do the pads line up i relation to the disc? Looks like you could of good a wee touch bigger in disk size? Maybe i'm wrong,just looking at the gap between the outer edge of the disc and the caliper.
There look top notch
what discs were used? i.e make and exact sizes
as i need 3 sets of discs
are the hi-spec discs?
same as my setup
can you pm me a price on the discs please
![](https://img.photobucket.com/albums/0703/RyanPestell/check.jpg)
same as my setup
![](https://img.photobucket.com/albums/0703/RyanPestell/back.jpg)
Graceland
i know what it weighs, i have a pair in my garage that i use as weights , they are that fookin heavy, we decided against using steel for that very reason, i may just weigh them again later
Surely unsprung weight is more important on a car used on bumpy surfaces? (i.e. a road car)
Not having a dig, just playing devil's advocate![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
They look ace by the way!![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Neil.
Neil.
Originally Posted by Thrush
Whats "unsprung weight" ??? ![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Basically to get the larger, heavier disc spinning takes more work then spinning a smaller lighter disc, thus you wont go as fast.
VERY basically and not very acuratly, but is the general idea
sprung weight is you sitting in the car.... you are supported by springs and their movement is controlled by the dampers.
things like wheels and brakes that are the wrong wide of the spring for it to have any effect are called "unsprung" weight
if we are not 'bothered' about 'unsprung weight' what is the nessesity for 'bigger brakes' ??
obviously , we are interested in going fast , otherwise we wouldnt need to have bigger brakes.
unsprung weight is very vital in the way a car turns/handles.
more later .................................................. ........................ if there is interest.
just wegh them brackets, i would like to bet they weigh near half the amount of the discs again ??????????????? EACH !
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![007](https://passionford.com/forum/images/smilies/bond.gif)
Markk - get a 'proper' explanation up! ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
My understanding is:
Unsprung weight is anything that moves with the road surface (so wheels, tyres, brakes, lower arms etc).
Sprung weight is anything that is isolated from the road by the suspension (Shell, engine, box, you).
Unsprung weight should be as low as possible as it affects the way the suspension behaves, and hence the handling of the car.
Neil.
Neil.
unsprung weight is the weight of the moving assembly the more weight you have in the wheels etc the slower it will be to react to change in direction and upsets the handling.
think of trying to disco dance with a house brick in each hand, with the 'unsprung weight' of the bricks at the end of the arm you aint going to be pulling the moves of john travolta so easily
I think that is the best description of unsprung weight I've ever read
Resident Wrestling Legend
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Fair play for having a go yourself Paul and Matt
and now proof of the pudding can be in the eating!
Team HOTHOT!
Originally Posted by martin-reyland
Those calipers look far too big for the disc that's being used... are the pads overhanging the outside of the disc?? fair play for having a go though.
A couple of mm overhand Martin - but this would be remedied by Matt using 330mm rotors instead of 325
However, that would require new bells, and different brackets, and we will be back to stage 1 of scratching our heads
Team HOTHOT!
ahh i used 350mm discs, with a pad depth area of 60mm.
as you can see, no pad overhang
![](https://img.photobucket.com/albums/0703/RyanPestell/bell-brk.jpg)
Cracking job lads
If hi-spec can offer a disc of this spec i would be very interested
Cracking job lads
