HELP NEEDED...(Please read)..UPDATED..just checked shells
Old Apr 25, 2006 | 09:54 PM
lawnsy's Avatar
lawnsy
Default HELP NEEDED...(Please read)..UPDATED..just checked shells
Right the first pic was my car at 8pm....i have had realy low oil pressure since buying the car and it has been getting worse but no bangs from the engine so i got sick and now it looks like the last photos.............I NEED YOU TO CONFIRM MY SUSPICIONS THAT MY 2WD SAFF HAS A 4WD OIL PUMP AND PICKUP PIPE (that was covered in some sort of silicone anyhow i have posted some pics of the work so far) any input welcome........
Old Apr 25, 2006 | 09:59 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yes, defo 4x4 pump
Old Apr 25, 2006 | 10:02 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Its a 4x4 pump alright, although I used a 4x4 oil pump, pick up and spray bar with a 2wd sump no problems. Did it have a sump gasket fitted or was it just gasket sealant ?
Old Apr 25, 2006 | 10:04 PM
Alvyn's Avatar
Alvyn
you can use a 4x4 pump and p/up just looks like who ever fitted the sump prior used too much of the that dreaded shit!
ps take a look at the big ends/ mains and also the condition of the pump seeing as it's had low pressure you may be lucky that there's no damage
Old Apr 25, 2006 | 10:15 PM
pee vee's Avatar
pee vee
EDIT ! Alvyn beat me to it lol
that slilcone on the pick up pipe is sealant from (probably the sump)
that COULD be whats causing your low pressure
tell you what mate, i would take a look at your bearings while you got it apart,, if the oil pressure has been that low,, it might not be such a great sight I know, cos ive just done exactly the same with mine tonight
having sent my oil pump back to cosworth
4x4 oil pump looks like this mate/
Old Apr 25, 2006 | 10:16 PM
lawnsy's Avatar
lawnsy
The sump was covered in hermotie as was the inlet ....does the 4x4 pickup pipe not sit to close to the 2wd sump?????? checked the oil pump and it looks ok no mojor scoring......not checked the shells yet having a few tins first before i pop back down..........oil pressure was down to 20psi on hot
Old Apr 25, 2006 | 10:26 PM
lawnsy's Avatar
lawnsy
any1???????
Old Apr 25, 2006 | 10:29 PM
SPADGE's Avatar
SPADGE
Don't talk to me about fookin silicone I dug this out of a YB a few weeks ago
Old Apr 25, 2006 | 10:32 PM
SPADGE's Avatar
SPADGE
As has been said mate pop a big end and main cap off and check the shells arn't mullered!
Old Apr 25, 2006 | 10:33 PM
lawnsy's Avatar
lawnsy
Fuck me ....mine was not that bad thank god.....i know 1 thing though there will not 1 drop of the stuff on the engine when it goes back together..
Was the engine ok?????
Old Apr 25, 2006 | 10:34 PM
lawnsy's Avatar
lawnsy
ill pop down now got me wondering now ...ill post some pics of findings
Old Apr 25, 2006 | 10:40 PM
SPADGE's Avatar
SPADGE
That engine was fooked but was past its 'sell by' date anyway so it didn't bother me
Old Apr 25, 2006 | 10:42 PM
pee vee's Avatar
pee vee
hope it ok for you mate
Old Apr 25, 2006 | 10:50 PM
lawnsy's Avatar
lawnsy
just checked shells and they are like new...even had arp bolts in ill post pics now
Old Apr 25, 2006 | 10:52 PM
lawnsy's Avatar
lawnsy
Old Apr 25, 2006 | 10:55 PM
pee vee's Avatar
pee vee
good news for ya then mate!!
chuck a new set in for good measure and a new set of bolts. away ya go!
Old Apr 25, 2006 | 10:56 PM
Kevin Sharp's Avatar
Kevin Sharp
4x4 pump and pick up pipe work perfectly with a 2wd sump fitted
Old Apr 25, 2006 | 10:57 PM
lawnsy's Avatar
lawnsy
they have only been in for about a 1000miles
Old Apr 25, 2006 | 11:05 PM
lawnsy's Avatar
lawnsy
well the shells are like new and the pump looks ok so if a 4x4 pump and pickup pipe is ok the only thing i can see is the shit on the pickup pipe but i would say only about half was covered would this be enough????
Old Apr 25, 2006 | 11:11 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
glad it didnt go pop lawnsy mate !!!
when will she be back out then ???
i would swap all the other gaskets if there half as shonky as them mate ??
hope u get it sorted son
beef
Old Apr 25, 2006 | 11:16 PM
lawnsy's Avatar
lawnsy
ill be back for the weekend got a fullengine gasket set to go on not taking head off though i want to goto york on sunday
Old Apr 26, 2006 | 07:53 AM
scruffythefirst's Avatar
scruffythefirst
I hope so, otherwise this isn't going to solve my problems
Old Apr 26, 2006 | 08:22 AM
lawnsy's Avatar
lawnsy
when i measured the bottom of pickup pipe from the bottom of block then measured the inside of the sump theres not much room pickup pipe is going to be sat really close to the inside of the sump also there was little marks on the inside of the sump were the pickup pipe sits looks like it has been vibrating and hitting the sump?????????? ive got a 2wd oil pump so i am going to try and get a pickup pipe and change it to make sure
Old Apr 26, 2006 | 08:59 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I do hope you sort it
Steve.
Old Apr 26, 2006 | 11:16 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
ford do a special sump sealer for 4x4 cosworth engines, that had no gasket, i would use that ,ive had no probs its only Ł7.50....
Also double check with your supplier that the part numbers on your new pump are not in those that are faulty...... and create too much pressure ,otherwise you will be doing it all over again.
Old Apr 26, 2006 | 02:50 PM
lawnsy's Avatar
lawnsy
You know when i said im sure the pickup pipe was sitting to close to the inside of the sump well look at this
see were it has been hitting...............so i am definately putting my 2wd pump&pipe on when i put it back together.....
Old Apr 26, 2006 | 03:33 PM
scruffythefirst
I was going to do that, then found out how much a 2wd pickup was and the fact i had to buy a new 2wd pump to go with it, I opted for modding my 4wd one.
Mines got the same pattern, but i'm not convinced its the pickup being too close thats caused it - its only been run for 5 minutes.
Old Apr 26, 2006 | 03:41 PM
lawnsy's Avatar
lawnsy
what sort of pressure are you getting???? does it change from cold to hot?????......i am getting 40psi at cold and 20-25psi at full temp, it is a 4wd 200block in a 2wd saff shells look mint as does oil pump, the only other thing i could think of apart from the oil pump is the little spring that go's in the side of the pump the one you change when you get the high pressure oil pump kit.....if this spring had lost it's goodness would this cause low oil pressure problem???????
Old Apr 26, 2006 | 05:42 PM
scruffythefirst
Well i was getting 65psi at cold idle for the first 60 secs, then absolutely zero. i tried it several times. Needless to say the engine hasn't run long enough to find out what its like hot.
4wd hp pump and pickup, 2wd sump on a 200 block. I measured the clearance between the pickup and the sump - its 6mm. Well it was untill i cut the pipe into 3 bits and had just the two brazed back together. Should have around 15mm clearance now
Will find out in about 3 hours if its worked.
Old Apr 26, 2006 | 09:20 PM
scruffythefirst
Shortening the pickup seems to have worked, won't be able to test it fully for a while, but its certainly got decent oil pressure all the time i ran it.
Old Apr 26, 2006 | 09:24 PM
lawnsy's Avatar
lawnsy
happy for you i know what its like......ive just cleaned my 2wd pickup pipe to put on but the oil pump looks a bit used so im going to buy a new one ive already got a high pressure oil pump kit to go in and see what happends.......
Old Apr 26, 2006 | 09:25 PM
lawnsy's Avatar
lawnsy
im blaming the 4x4 pickup pipe though for my probs
Old Apr 26, 2006 | 09:28 PM
scruffythefirst
Its been a bit of a mission, sumps been on and off about 8 times in the last week
Old May 5, 2006 | 06:20 PM
scruffythefirst
Well its still fucked. It was working perfectly, 65psi, the flutter from the guage had dissapeared, the turbo and lifters had shut up. then a quick blast up and down the drive, blip the revs a bit and zero oil pressure
So culprit could be one of several things.
Guage and warning light faulty
remote filter and pipework faulty
pressure releif valve sticking open, closes when cranked on the starter
pickup still too close to the sump
something I haven't thought off
Old May 5, 2006 | 06:48 PM
pee vee's Avatar
pee vee
mate there is almost No way the Light AND the gauge are faulty
PLEEEEASE dont use the car again till you fixed it!!
mine only ran twice with similar problems and i ended up having to buy a new crank where it got so damaged.
Old May 5, 2006 | 06:54 PM
pee vee's Avatar
pee vee
Also.. your remote oil filter,, the sandwich plate isnt a thermostat type one is it?? opens when the oil reaches certain temp???
(might of been put on by mistake?)
if so could that have something to do with it??
Old May 5, 2006 | 06:58 PM
_DAN_'s Avatar
_DAN_
Yoon
Hasn't the 4wd pump got two feeds to the rotor instead of one?
Old May 5, 2006 | 07:12 PM
scruffythefirst
Nope
Its not even registered yet, so i've decided to fix it by drinking beer Felt fantastic driving it up and down the drive, well untill it went tits up
Not sure what you mean? There's only one pickup pipe
Old May 5, 2006 | 07:13 PM
_DAN_'s Avatar
_DAN_
Yoon
Two feeds to the rotor i heard,prob shite
Old May 6, 2006 | 08:36 AM
scruffythefirst
Anyone else?
