Lambda sensor position
Old Apr 24, 2006 | 09:37 AM
Willem's Avatar
Willem
Default Lambda sensor position
I want to put a lambda sensor in my exhaust system, but I'd like to know where to put it best.
What distance from the turbo, inner bend, outer bend or on the side???
Who can tell me something about this???
Thnx
Old Apr 24, 2006 | 09:41 AM
Just after the turbo gets my vote, at the top of the pipe so its easy to get to.
Keeping it close means it will be up to temp more quickly.
Old Apr 24, 2006 | 09:53 AM
Willem's Avatar
Willem
Can it get too hot or will it never get too hot to let the sensor die instantly??
Old Apr 24, 2006 | 09:54 AM
I tihnk you would have bigger things to worry about first if the exhaust gasses after the turbo were so hot they killed a lambda sensor mate!
Old Apr 24, 2006 | 09:58 AM
Willem's Avatar
Willem
don't know how fragile those sensors are, but according to you, that won't be a problem thnx for the info!!
Old Apr 24, 2006 | 10:04 AM
They dont even START working till they are at 300+ degrees mate, and are quite happy to sit there at 1000 degrees if they need to.
But yours wont ever see that if its after the turbo.
Old Apr 24, 2006 | 10:08 AM
Willem's Avatar
Willem
why don't i read that info on lambdasensor.com? thnx again :-p
Old Apr 24, 2006 | 10:11 AM
Jay,'s Avatar
Jay,
Sponsor
mine sits 12 inches away from the turbo
Old Apr 24, 2006 | 10:13 AM
Willem's Avatar
Willem
is that the std distance??
Old Apr 24, 2006 | 10:16 AM
Jay,'s Avatar
Jay,
Sponsor
well thats where most after market ones are fitted where ive seen also mines heated and has been there for 6 months with no worries
Old Apr 24, 2006 | 10:21 AM
Willem's Avatar
Willem
ok, got another question, how much better is the titania sensor to the zirconia sensor??
Old Apr 24, 2006 | 10:26 AM
Jay,'s Avatar
Jay,
Sponsor
lost me lol i use a bosch ls 4.2 which is a vw sensor. CHIP what u recon lol
Old Apr 24, 2006 | 10:34 AM
Stu@MSD has done some back to back tests i beleive?
PM him and ask him to pop into this thread as he doesnt get a chance to read every thread.
Old Apr 24, 2006 | 10:35 AM
Just had a quick look at that site and doesnt seem to have much info on there
Old Apr 24, 2006 | 10:40 AM
zvhturbo's Avatar
zvhturbo
About 12 inchs from the turbo will be fine.
Make sure the wires are pointing upwards (and not less than 25 degrees to horizontal) to ensure any condensation drains out of the sensor.
Heated sensors will reach operating temperature in approx 20 seconds so it doesn't really matter if you can't get very close to the turbo, as long as the air passing the sensor is only from the engine and no air is drawn in from exhaust joints etc.
Old Apr 24, 2006 | 10:41 AM
Willem's Avatar
Willem
was a bit dissapointing indeed.
PM has been send.
Old Apr 24, 2006 | 11:30 AM
Willem's Avatar
Willem
Nice tip m8, you can only weld the nut on the exhaust once :-p
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
