Rev Counter problem??
Old Aug 3, 2004 | 10:30 AM
SapphyMike's Avatar
SapphyMike
Default Rev Counter problem??
My rev counter on my cossie keeps stopping working... then suddenly it'll start working?! It wasnt working this morning until i went over some bumps and then it kicked into life.. dicky rev counter??
Old Aug 3, 2004 | 11:04 AM
rstoughy's Avatar
rstoughy
Could be. My rev counter on my 4x4 started playing up reading 4000rpm while engine was on idle then not climbing when rising through rev range. car also started to miss on hard acceleration and full bost so changed the coil and everything seems fine now. I have heard of the actual rev counter packing up on cossies though.
Old Aug 3, 2004 | 11:17 AM
SapphyMike's Avatar
SapphyMike
might just get a new set of clocks..
Old Aug 3, 2004 | 11:43 AM
Matt's Avatar
Matt
theres only 2 inputs and a ground, the +ve and -ve are simple to trace, black/yellow is +ve if i remember rightly, brown will no doubt be brown, the signal input from the coil is the green cable second in from left here....
if saph clocks aint got the same loom then you'll have to strip the clocks to see whats what, i understood it so it aint rocket science
Old Aug 3, 2004 | 11:49 AM
SapphyMike's Avatar
SapphyMike
why would i want to trace it matt? break in the wire?
Old Aug 3, 2004 | 11:53 AM
Matt's Avatar
Matt
suggest you try breaking into the signal feed from the coil about an inch in from the clock multiplug and running it to the coil, or if you know how (i didnt) measure the resistance of that wire to see if theres a break etc
Old Aug 3, 2004 | 11:56 AM
SapphyMike's Avatar
SapphyMike
Could do a continuity test i guess!
Its not a constant problem which is anoying lol
Old Aug 3, 2004 | 12:09 PM
Matt's Avatar
Matt
...which makes it sound like a lose connection/semi broken wire
Old Aug 3, 2004 | 02:35 PM
SapphyMike's Avatar
SapphyMike
Hmmmmmmmmmmmm, looks like its dash out time then.... fun fun fun!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
