Front driveshaft replacement
Has anyone put one of the graham goode extened o/s driveshafts in a 4x4 saff cosworth.
If so did it fit ok, was yours lowered or standard height?
Thanks
Thanks
just use the xr4x4 ones out of a 2.9 as these are longer
may as well change them both to be honest i did and never had any probs after that
my car was lowered on custom springs around 70-80mm drop which is way to low for a 4x4 when i had the cossie shaft snap i put these in and had no probs what so ever
Get on That!
and the shafts aren't so much of the issue it the engine mount that breaks which then causes it to pull on the CV joint which then of cause leads to it breaking
And lowering a 4x4 cossie more than about 25mm fuks up its handling anyhow.
oh and exactly what pete says too
markk
18
17-08-2015 05:19 AM
