cosworth alloy bottom pullys
cosworth alloy bottom pullys for a 2wd that main pully with the pick up lugs is this a problem it being alloy as i was thinking of a pully set all made from alloy
try it again with punctuation?
if you mean the 4 lugs, alloy won't work, they need to be ferrous, the way A1 rally do theirs is to use 4 grub screws screwed into the ally at the appropriate places
some places use an alloy pulley attached to a metal back-plate with the lugs on..
borboyous
22-08-2015 11:17 AM
lockie
31-07-2015 10:03 PM
