A simple engine question.....
Chip, what is the magic 5252 number in that equation?
It IS just a number in an equation, but it implictly defines the cross over the point for torque and horsepower in lbft and BHP.
If you quote in NM and PS you get a different number, and hence a different crossover point.
5252 is the point in the RPM range when ALL engines will have the same power and torque if they are quoted in lbft and bhp
Where could I read all about this stuff as it fascinates me. I've only really started to get into the ins and outs of engines in the last year since I had to rebuild my 2 stroke mx bike engine. And realised I didnt actually understand how engines make power etc etc.
I dont actually know of a book that details all this sort of stuff, im not really one for reading about engiens TBH, i have learnt just from trial and error and talking to others who know more, although a background in physics and chemistry etc certainly helps me.
Yes if at 5252 rpm a formula 1 engine is 270lbft (bare in mind torque changes at each point in the rev range too!) then it would be 270bhp
Motorbike engines are similar, you have to ring their necks to get the power out!
Originally Posted by jock
Why is that Chip i have heard it talked about and have seen it on a bunch of graphs i have had from my cars but never been told why ???
Mike
Mike
In order to manage peak cylinder pressure points within the cycle.
If you have more boost then it takes longer forthe flame front to propogate which means that you have to retard the timing to avoid detonation occuring.
Fuck, that doesnt read very easily, umm, lol
Attempt 2:
Basically when your car fires, its NOT an explosion of fuel and air, its a burn, as this burn happens gasses are given off (exaust) which pressurise the cylinder.
If the pressure in the cylinder goes past a certain number of PSI then the fuel/air mix can ignite on its own, before the burn gets to it, so the whole lot goes up at once (THIS is an explosion).
So what you have to do is manage the amount of pressure that builds from the burn to make sure it NEVER reaches that point, but you want to be JUST before it, or you are wasting power.
So the more boost you cram in, the more you have to start the burn happening while the piston is further back in the cycle, so that you dont end up with this happening.
Not an easy thing to explain in a post really TBH
Question me further if ive still not made that clear?!
Mike
Originally Posted by Doug Stirling
The reason the high comp engines give relatively low torque is as Chip explained - high comp engines can't run as much boost as low comp engines. Boost = torque.
What sort of application are these for?And how would a big power (say over 600 BHP) road car engine perform on such low comp pistons?
Neil Callan runs 6:9:1 cosworth pistons and a kkk turbo so best ask him.
Maltese run big power on 6:8:1, 6:9:1 etc they get good power and don't have to use much boost even on shit fuel.
Oh you were asking about the 5252 thing, i was replying as to why your car needs ignition retard, LOL!!!!
It happens at 5252 because thats how BHP is define, the same that EVERY speedo has MPH and KMH set so that at 160 KMH its 100MPH or that 12" always equals 30cm
BHP is defined as
LbFt / 5252 * rpm = BHP
So if you are dividing by 5252 and multiplying by 5252 they cancel each other out and you are left with LbFt = BHP
Its true by the definition of BHP.
Attempt 2:
Thanks for the reply, i understand what you have said but why does it always happen at the exact point not say 400rpm earlier or later ?
Mike
BHP is defined as
Mike
Mike
Attempt 2:
Mike
This may help on 5252 :
Force, Work and Time
If you have a one pound weight bolted to the floor, and try to lift it with one pound of force (or 10, or 50 pounds), you will have applied force and exerted energy, but no work will have been done. If you unbolt the weight, and apply a force sufficient to lift the weight one foot, then one foot pound of work will have been done. If that event takes a minute to accomplish, then you will be doing work at the rate of one foot pound per minute. If it takes one second to accomplish the task, then work will be done at the rate of 60 foot pounds per minute, and so on.
In order to apply these measurements to automobiles and their performance (whether you're speaking of torque, horsepower, newton meters, watts, or any other terms), you need to address the three variables of force, work and time.
Awhile back, a gentleman by the name of Watt (the same gent who did all that neat stuff with steam engines) made some observations, and concluded that the average horse of the time could lift a 550 pound weight one foot in one second, thereby performing work at the rate of 550 foot pounds per second, or 33,000 foot pounds per minute, for an eight hour shift, more or less. He then published those observations, and stated that 33,000 foot pounds per minute of work was equivalent to the power of one horse, or, one horsepower.
Everybody else said OK.
For purposes of this discussion, we need to measure units of force from rotating objects such as crankshafts, so we'll use terms which define a *twisting* force, such as foot pounds of torque. A foot pound of torque is the twisting force necessary to support a one pound weight on a weightless horizontal bar, one foot from the fulcrum.
Now, it's important to understand that nobody on the planet ever actually measures horsepower from a running engine. What we actually measure (on a dynomometer) is torque, expressed in foot pounds (in the U.S.), and then we *calculate* actual horsepower by converting the twisting force of torque into the work units of horsepower.
Visualize that one pound weight we mentioned, one foot from the fulcrum on its weightless bar. If we rotate that weight for one full revolution against a one pound resistance, we have moved it a total of 6.2832 feet (Pi * a two foot circle), and, incidently, we have done 6.2832 foot pounds of work.
OK. Remember Watt? He said that 33,000 foot pounds of work per minute was equivalent to one horsepower. If we divide the 6.2832 foot pounds of work we've done per revolution of that weight into 33,000 foot pounds, we come up with the fact that one foot pound of torque at 5252 rpm is equal to 33,000 foot pounds per minute of work, and is the equivalent of one horsepower. If we only move that weight at the rate of 2626 rpm, it's the equivalent of 1/2 horsepower (16,500 foot pounds per minute), and so on. Therefore, the following formula applies for calculating horsepower from a torque measurement:
Torque * RPM
Horsepower = ------------
5252
This is not a debatable item. It's the way it's done. Period.
The Case For Torque
Now, what does all this mean in carland?
First of all, from a driver's perspective, torque, to use the vernacular, RULES
. Any given car, in any given gear, will accelerate at a rate that *exactly* matches its torque curve (allowing for increased air and rolling resistance as speeds climb). Another way of saying this is that a car will accelerate hardest at its torque peak in any given gear, and will not accelerate as hard below that peak, or above it. Torque is the only thing that a driver feels, and horsepower is just sort of an esoteric measurement in that context. 300 foot pounds of torque will accelerate you just as hard at 2000 rpm as it would if you were making that torque at 4000 rpm in the same gear, yet, per the formula, the horsepower would be *doubled* at 4000 rpm. Therefore, horsepower isn't particularly meaningful from a driver's perspective, and the two numbers only get friendly at 5252 rpm, where horsepower and torque always come out the same.
In contrast to a torque curve (and the matching pushback into your seat), horsepower rises rapidly with rpm, and especially so when torque values are also climbing. Horsepower will continue to climb, however, until well past the torque peak, and will continue to rise as engine speed climbs, until the torque curve really begins to plummet, faster than engine rpm is rising. This is a key point. If you mess about with the formula, you can see that, as long as torque values aren't dropping at a rate that is as great or greater than the rise in rpm, horsepower will climb.
However, as I said, horsepower has nothing to do with what a driver *feels*.
You don't believe all this?
Fine. Take your non turbo car (turbo lag muddles the results) to its torque peak in first gear, and punch it. Notice the belt in the back? Now take it to the power peak, and punch it. Notice that the belt in the back is a bit weaker? Fine. Can we go on, now?
The Case For Horsepower
OK. If torque is so all-fired important, why do we care about horsepower?
Because (to quote a friend), "It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*".
For an extreme example of this, I'll leave carland for a moment, and describe a waterwheel I got to watch awhile ago. This was a pretty massive wheel (built a couple of hundred years ago), rotating lazily on a shaft which was connected to the works inside a flour mill. Working some things out from what the people in the mill said, I was able to determine that the wheel typically generated about 2600(!) foot pounds of torque. I had clocked its speed, and determined that it was rotating at about 12 rpm. If we hooked that wheel to, say, the drivewheels of a car, that car would go from zero to twelve rpm in a flash, and the waterwheel would hardly notice
On the other hand, twelve rpm of the drivewheels is around one mph for the average car, and, in order to go faster, we'd need to gear it up. In fact, gearing up (so as to increase the speed of the output), means that you lose torque at the output in a proportional manner. That is, if you gear up the output for twice the speed, you lose half the torque at the output, and so on.
To get to 60 mph would require gearing the wheel up enough so that it would be effectively making a little over 43 foot pounds of torque at the output (one sixtieth of the direct torque), which is not only a relatively small amount, it's less than what the average car would need in order to actually get to 60. Applying the conversion formula gives us the facts on this. Twelve times twenty six hundred, over five thousand two hundred fifty two gives us:
6 HP.
Oops. Now we see the rest of the story. While it's clearly true that the water wheel can exert a *bunch* of force, its *power* (ability to do work over time) is severely limited.
At The Dragstrip
OK. Back to carland, and some examples of how horsepower makes a major difference in how fast a car can accelerate, in spite of what torque on your backside tells you
A very good example would be to compare the current LT1 Corvette with the last of the L98 Vettes, built in 1991. Figures as follows:
Engine Peak HP @ RPM Peak Torque @ RPM
L98 250 @ 4000 340 @ 3200
LT1 300 @ 5000 340 @ 3600
The cars are geared identically, and car weights are within a few pounds, so it's a good comparison.
First, each car will push you back in the seat (the fun factor) with the same authority - at least at or near peak torque in each gear. One will tend to *feel* about as fast as the other to the driver, but the LT1 will actually be significantly faster than the L98, even though it won't pull any harder. If we mess about with the formula, we can begin to discover exactly *why* the LT1 is faster. Here's another slice at that formula:
Horsepower * 5252
Torque = -----------------
RPM
If we plug some numbers in, we can see that the L98 is making 328 foot pounds of torque at its power peak (250 hp @ 4000), and we can infer that it cannot be making any more than 262 pound feet of torque at 5000 rpm, or it would be making 250 hp or more at that engine speed, and would be so rated (262 foot pounds times 5000, over 5252 = 249 hp). If it were making 263 or more foot pounds of torque at 5000 rpm, it would be making 250 or more hp, and Chevrolet would likely publish that peak figure and engine speed. In actuality, the L98 is probably making no more than around 210 pound feet or so at 5000 rpm, and anybody who owns one would shift it at around 46-4700 rpm, because more torque is available at the drive wheels in the next gear at that point.
Note: This is a side point, but the optimum shift point for best acceleration occurs at a time when the torque at the drive wheels in the next gear just equals the torque at the drive wheels in the current gear. You shift well above the power peak (and obviously way past the torque peak), because the next gear gives you less mechanical advantage (less torque multiplication) than the gear you're in. As an example, with a 3.00:1 first gear and a 2.00:1 second gear, you wouldn't want to shift until the torque curve dropped by at least 33% from peak - and even then, that would only be true assuming that you'd be *at* the torque peak in the next gear. Otherwise, you'd shift even later. As a practical matter, this usually means shifting at an engine speed of 10 - 15% above the power peak with two-valve engines, and at the redline in four-valve engines, or maybe even the rev limiter
. If you know your torque curve and gearing, you can plot this out yourself. If you do this, drop your one-two shift point 2-4% from the calculated optimum, and by lesser amounts in subsequent shifts, to account for flywheel effect. More on that later.
OK. Back to the hp vs torque comparison.
As we've said, the L98 has dropped way off on torque by 5000 rpm, but on the other hand, the LT1 is fairly happy making 315 pound feet at 5000 rpm (300 hp times 5252, over 5000), and is happy right up to its mid 5s redline.
So, in a drag race, the cars would launch more or less together. The L98 might have a slight advantage due to its peak torque occuring a little earlier in the rev range, but that is debatable, since the LT1 has a wider, flatter curve (again pretty much by definition, looking at the figures). From somewhere in the mid range and up, however, the LT1 would begin to pull away. Where the L98 has to shift to second (and throw away torque multiplication for speed), the LT1 still has around another 1000 rpm to go in first, and thus begins to widen its lead, more and more as the speeds climb. As long as the revs are high, the LT1, by definition, has an advantage.
Another example would be the LT1 against the ZR-1 Vette. Same deal, only in reverse. The ZR-1 actually pulls a little harder than the LT1, although its torque advantage (385 foot pounds at 5200 rpm) is softened somewhat by its extra weight. The real advantage, however, is that the ZR-1 has another 1500 rpm in hand at the point where the LT1 has to shift.
There are numerous examples of this phenomenon. The Integra GS-R, for instance, is faster than the garden variety Integra, not because it pulls particularly harder (it doesn't), but because it pulls *longer*. It doesn't feel particularly faster, but it is.
A final example of this requires your imagination. Figure that we can tweak an LT1 engine so that it still makes peak torque of 340 foot pounds at 3600 rpm, but, instead of the curve dropping off to 315 pound feet at 5000, we extend the torque curve so much that it doesn't fall off to 315 pound feet until 15000 rpm. OK, so we'd need to have virtually all the moving parts made out of unobtanium
, and some sort of turbocharging on demand that would make enough high-rpm boost to keep the curve from falling, but hey, bear with me.
If you raced a stock LT1 with this car, they would launch together, but, somewhere around the 60 foot point, the stocker would begin to fade, and would have to grab second gear shortly thereafter. Not long after that, you'd see in your mirror that the stocker has grabbed third, and not too long after that, it would get fourth, but you'd wouldn't be able to see that due to the distance between you as you crossed the line, *still in first gear*, and pulling like crazy.
I've got a computer simulation that models an LT1 Vette in a quarter mile pass, and it predicts a 13.38 second ET, at 104.5 mph. That's pretty close (actually a bit conservative) to what a stock LT1 can do at 100% air density at a high traction drag strip, being powershifted. However, our modified car, while belting the driver in the back no harder than the stocker (at peak torque) does an 11.96, at 135.1 mph, all in first gear. It doesn't pull any harder, but it sure as hell pulls longer. Per the formula, it's also making *900* hp, at 15,000 rpm (315 foot pounds times 15000, over 5252).
Of course, folks who are knowledgeable about drag racing are now openly snickering, because they've read the preceeding paragraph, and it occurs to them that any self respecting car that can get to 135 mph in a quarter mile will just naturally be doing this in less than ten seconds. Of course that's true, but I remind these same folks that any self-respecting engine that propels a Vette into the nines is also making a whole bunch more than 340 foot pounds of torque.
That does bring up another point, though. Essentially, a more "real" Corvette running 135 mph in a quarter mile (maybe a mega big block) might be making 600 or more foot pounds of torque, and thus it would pull a whole bunch harder than my paper tiger would. It would need slicks and other modifications in order to turn that torque into forward motion, but it would also get from here to way over there a bunch quicker.
On the other hand, as long as we're making quarter mile passes with fantasy engines, if we put a 10.35:1 final-drive gear (3.45 is stock) in our fantasy LT1, with slicks and other chassis mods, we'd be in the nines just as easily as the big block would, and thus save face
. The mechanical advantage of such a nonsensical rear gear would allow our combination to pull just as hard as the big block, plus we'd get to do all that gear banging and such that real racers do, and finish in fourth gear, as God intends.
The only difficulty with such aggressive gearing would be that it would introduce really massive polar moments of inertia (flywheel effect), and that rather complex topic is best addressed through a document of its own, though I'll take an abbreviated poke at it in the next several paragraphs.
Suffice it to say that rotating objects tend to resist either acceleration or deceleration, and engine components are no exception. Gearing up (by either selecting first gear, or in fact tripling the final drive ratio, as we've done with the Vette) means that the engine and other rotating components have to speed up by a greater amount for every mph the vehicle gains, so more energy is expended in accelerating these items to gain a given amount of speed, and thus less energy is available to actually belt you in the back.
As an example of how flywheel effect dampens performance, my old '85 Vette would pull .50 Gs at peak torque in its 1.91 second gear (measured with a Vericom). With a 2.88 first gear, one would expect it to pull around .75 Gs (2.88 over 1.91 = 1.51, times .50 Gs = .75 Gs). It would actually pull a peak of .66 Gs in first gear. The difference can be attributed to a tad more tire slip (maybe sucking up .01 G at most) and the fact that first gear is marginally less efficient than second in most transmissions, thereby sucking up another .01 G (or less), but the main reason that first won't pull as hard as you'd expect (in *any* car) is that the engine uses more energy accelerating itself in first than in second (to gain the same amount of speed), so you get less energy at the drive wheels. This is why you adjust calculated shift points downward, since the actual torque available at the drive wheels is always reduced a bit from what you would calculate it to be, compared to the next higher gear. Flywheel effect goes up as the square of the gearing, which is one reason why the one-two shift point is affected the most.
In the example I used of the 900 hp LT1 using 10.35 gears, the car would drop into the nines for a quarter mile, but in so doing, the trap speed would climb to about 148 mph, because the car is essentially putting more average power to the track with the stiffer gearing. However, drag race nuts are snickering again, because any self-respecting car that can get to 148 mph in a quarter mile ought to be able to do this somewhere in the mid eight second bracket.
The reason this fantasy car doesn't get into the eights is that, in order to get it to effectively use its power, we had to gear it so stiffly that flywheel effect took a major toll from its relatively paltry 340 foot pounds of torque, and since flywheel effect is most pronounced in the lower gears, elapsed times suffer, while trap speeds are affected less.
You can see why drag racers think torque is what wins races. It isn't strictly true, but high rpm, low torque (as opposed to lower rpm, high torque) cars are at a disadvantage in a drag race as long as overall power to weight is similar, because they either only start getting effective somewhere down track (thus crippling elapsed times), or they suffer greater flywheel effect if you gear them aggressively enough to create high torque at the drive wheels (thus crippling elapsed times).
What's really needed in a drag race is high torque (for that massive belt in the back) *and* high horsepower (extending the torque curve), so you can take advantage of gearing.
Of course, looking for top speeds, it's a simpler story......
At The Bonneville Salt Flats
Looking at top speed, horsepower absolutely wins, in the sense that making more torque at high rpm means you can use a stiffer gear for any given car speed, and thus have more effective torque *at the drive wheels*. Remember, there isn't any flywheel effect at top speed because you're not accelerating.
Finally, operating at the power peak means you are doing the absolute best you can at any given car speed, measuring torque at the drive wheels. I know I said that acceleration follows the torque curve in any given gear, but if you factor in gearing vs car speed, the power peak is *it*. An example, yet again, of the LT1 Vette will illustrate this. If you take it up to its torque peak (3600 rpm) in a gear, it will generate some level of torque (340 foot pounds times whatever overall gearing) at the drive wheels, which is the best it will do in that gear (meaning, that's where it is pulling hardest in that gear).
However, if you re-gear the car so it is operating at the power peak (5000 rpm) *at the same car speed*, it will deliver more torque to the drive wheels, because you'll need to gear it up by nearly 39% (5000/3600), while engine torque has only dropped by a little over 7% (315/340). You'll net a 29% gain in drive wheel torque at the power peak vs the torque peak, at a given car speed. (This is another reason why you *must* be at least at the power peak (or higher in most cases) before you shift to the next gear.)
Any other rpm (other than the power peak) at a given car speed will net you a lower torque value at the drive wheels. This would be true of any car on the planet, so, theoretical "best" top speed will always occur when a given vehicle is operating at its power peak.
"Modernizing" The 18th Century
OK. For the final-final point (Really. I Promise.), what if we ditched that water wheel, and bolted an LT1 in its place? Now, no LT1 is going to be making over 2600 foot pounds of torque (except possibly for a single, glorious instant, running on nitromethane), but, assuming we needed 12 rpm for an input to the mill, we could run the LT1 at 5000 rpm (where it's making 315 foot pounds of torque), and gear it down to a 12 rpm output. Result? We'd have over *131,000* foot pounds of torque to play with. We could probably twist the whole flour mill around the input shaft, if we needed to
The Only Thing You Really Need to Know
Repeat after me. "It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*." For any given level of torque, making it at a higher rpm means you increase horsepower - and now we all know just exactly what that means, don't we
Thanks for your time.
Bruce
I didnt write it though and you will have to live with the formatting
WD
Torque * RPM
5252
The Case For Torque
6 HP.
At The Dragstrip
Horsepower * 5252
RPM
Bruce
WD
Woooooosssshh!!!
Its off some site like "how stuff works" or something like that probably.
Maybe he will post the original link so that you can read it with formatting and see how simple it is then!
Or failing that, i can disucss it with you over pizza on sunday instead of the usual gutter talk that ensues at the PF mate, LOL
Mike Rainbird
Bosch-Man
Also Mike you say lo comp can run higher boost...yet a rally car runs a 3bar boost spike do they not on like 9.5-1 engines and make about 500ft lb.....IF hi comp was so spaz why dont rally cars run lo comp and get more reliability...there must be an advantage to hi comp
Itsmeagain
RACE FUEL you fool.
If you ran their engine specs on pump fuel itd end in a big bang very quickly, and if you re-mapped and re-boosted their engines to run safe on pump fuel you will have fuck all worthwhile.
RACE FUEL you fool.
fookin bollox, 90 % of the clubman rally cars will NOT run race fuel, only a very small percentage will due to the costs, the gains are not enough to justify the costs, and is not necessarily needed cue ........tim finch,
clubman rally cars do include wrc and group a vehicles on a regular basis.
chip-3door
IF your brief it so hunt for as much torque as possible (ie the thread subject) on an unrestricted (ie not a rally car which are limited by rules) engine then you want low cr.
If rally cars didnt have the restrictor, they would run lower CR, simple as that, the high CR is there because the restrictor is there
i also have a map in my ecu for when i run non-restricted, i dont have a switch to instantly drop the CR, nor would i want one.
Itsmeagain
Low and High is relative purely to the fuel used tho IMO.
And as we talking about pump fueled road cars, Mike is right.
We not talking about restricted, race fueled, cars.
For the race fuel they run, WRC engines are quite low comp, but theyd go far lower if they didnt have the restrictor, they need to make the most power from the RESTRICTED airflow they got, with the fuel they got, hence the comp they use.
Simple maths that theyd do.
We havent a airflowe restriction.
im not going to quote anymore of this thread, i think you can see, the people who comment on hi v low, have not had/used a high comp motor for any particular reason, just out of interest, what do we constitute as hicomp these days for a YB ?
8.0 :1 ?
9.0:1 ?
higher ????
i know what ive run for the last 7 years as hi comp, and trust me, by todays standards its no where near hi comp
but i like it, it drives nice, performs nice, and has been very reliable.as for egt's etc , well , bad heat managment will always end your engine, especially if your just gonna read a book about it ( sorry internet forum) like alot of what seams to go on these days, if one person says its wrong every one must be wrong.
dont forget though guys, the YB series is essentially a late 1970's engine really, and although mick and keith though brilliant engineers, they did not try every engine , in every scenario, in every condition, to very spec.
Mike Rainbird
Phil,
run a rally car / WRC car on normal Super-unleaded and see how long it lasts . IF pump fuel was as a higher octane, I would gladly be running higher compression, as it would be a win-win situation. Unfortunately it isn't. It is much safer / better more power to run low compression high boost then having to run the retard you are running to allow the boost you are running. Perhaps you should stick an EGT gauge on your car to frighten yourself .
Phil,
how about the equivilant of 600 continuous flat out miles ?? , hows that for a hi comp on pump fuel at +30lb on a T34
not forgetting the road sections and road miles whilst testing these will be in the thousands.
mike, you listen to harvey gibbs to much pal
Well said Markk...mucho bollocks wrote on here and its not ALL from me!
My T4 is hitting silly boost at 8-1 comp
probably more than most lo comp engines
BUT i have beautiful drivability off boost and thats 0-4000rpm of it
...This engine was built and specced to do a job and i feel does it well....The trouble with Mike R is he really IS stuck in the dark ages like his dress sense
There is a world OUTSIDE Harvey
...you know people thought i mindlessly chucked this engine together WRONG...i listened to people like Markk people who actually KNOW about these things not people who THINK they know!
Jullian Godfrey for example!!!You are insulting him more than anyone people!!!...I think he knows more thru experience rather than theory
If i had listened to Mike R only i'd be 6-1 comp and sporting a mullet
89xr2....of course i knew it(by asking people that knew it!)...but i couldnt argue the toss as i am only now experiencing it.....I talk from EXPERIENCE not theory...i go on to Rainbird all the time about my comp he refuses to accept its right for the turbo and boost
It didnt sound like you knew it though through previous posts of yours. Either way your sierra sounds like its a proper weapon
kk, im confused but o have a few qus
tx says hp and tourque become relative at 5250- so how does work with diesle engines? or engines with peak power figure below this rpm.
is this why diesle cant make big hp figure?
and why they make mahoosive tourque?
There will be no input from Mike/Chip/Itsmeagain cause Markk has done a real
on them
Theory Vs Reality
on them
Theory Vs Reality
very good thread this.
even if i was being pedantic at the beginning of it (sorry steve, i know that you know the score, and i was trying to make you look silly), i hope that some good has come out of it, and some people understand a little more about the relationship between torque and power.
as they say - torque accelerates cars, power sells them
Mark,
I've seen the difference the fuel makes and it is a MINIMUM of 40bhp on Harvey's dyno on a restricted engine. That is a WORLD of difference in power and response of an engine running pump fuel and an engine running race fuel, when 310-320bhp is the maximum achievable on a restricted engine.
If you're really stupid enough to believe there is no significant difference between a restricted engine on high octane race fuel and one on pump fuel, then you're more stupid than I thought
Obviously the pump fuel cars run significantly compromised compared to those that run race fuel - if there wasn't any difference, then the factory teams wouldn't be chasing every single bhp / lb ft running compression ratios in double figures
. You put one of these engines on pump fuel and it wouldn't last a stage mile, that's FACT
You can build a pump fuel rally engine, but a race fuel engine will walk all over it, so I can't understand what it is you're trying to say
. It sounds like you're implying pump fuel cars run comparitive power, which is just laughable.
Unless of course you're suggesting that you can change the laws of physics in the same way that Jesus turned water to wine, you're turning Optimax to Elf turbo fuel
.Obviously the pump fuel cars run significantly compromised compared to those that run race fuel - if there wasn't any difference, then the factory teams wouldn't be chasing every single bhp / lb ft running compression ratios in double figures
. You put one of these engines on pump fuel and it wouldn't last a stage mile, that's FACT You can build a pump fuel rally engine, but a race fuel engine will walk all over it, so I can't understand what it is you're trying to say
mike , you enjoy the dyno, i'll enjoy the real world of rallying
i didnt say that there was no difference in running between pump and race, in fact running race fuel does have disadvantages if you would like to do a little 'research'. but you do have some rather serious blinkers pal as to 'what your told'.
if you think a car cannot run doubel figured cr, and pump fuel without vgood performance then sadly for you, your very wrong. i myself are having to convert to 4wd due to the fact that i cant use all of my available power anymore in my chosen sport in this country. i would expect the 'works' teams to be chasing more and every ft/lb available, as this is where the window of development is always open, but for you to say we cant run the same cr and have reliability, or an engine that will perform exceptionally well in its field, thats just complete blinkered bollox,
of course i couldnt use a works full spec engine/ecu/map etc on pump fuel, even you should know thats not possible.
i thought people used to just take the piss out of you/your knowledge because it was fun, not because it was true
Originally Posted by markk
oh and btw , the differance on a group a escort map from optimax to careless works to approx 40ft/lb, sorry we dont do bhp
. It just seems that you are implying that no such changes have to be made - if that were true, then there were would be no adavantages running high octane fuel.I agree that at your current level, the power you have is more than adequate (and would certainly be too much for me on loose surfaces
). However, I suspect that with the four wheel drive in place, you will feel that you will want more power, as the ability to lay the power down that you have will now be increased significantly. I wouldn't be surprised if after a few months of competing with 4wd, you will be wanting more power Accordingly, I fail to see why you think I'm blinkered, as I understand the compromises required to make an engine reliable depending on compression being run, but YOU don't seem to be able to grasp this simple principal
. All you have to do is look at an engine that has been recently given a lot of publicity - Yum's big power engine. This has been mapped to the limit of the turbo on pump fuel and gave 620bhp. The fuel was changed for a high octane variety, a few degrees of ignition mapped in a across the range, and voila, almost 50bhp extra and a shit load of torque for no mechanical changes what-so-ever. That tells you ALL you need to know about the benefits of race fuel and the compromises needed mapping for pump fuel by comparison
.Even Steve who I know would love to have the opportunity to disagree with me and give me a
in my ass, is confirming everything I am saying. So who is it with the blinkers again?
Mike Rainbird
as for yums engine, i know he made 50horse more, what was the torque differance though, and from what i remember on race fuel the peak was at higher revs ?? ( i stand to be corrected) what your missing is that that engine had not hit its intake restriction, take off the mis inlet and fit a std 2wd unit then retest it, just like 99% of the cosworth owners inlet system, like i said, my restriction is a 34 unit, the cosworth std restriction is a the elbow in the inlet, im not talking physics, but there are other ways that will work, just because you have been told they wont doesnt mean they wont.
most engines are mapped to a compromise, most have something that could be better, unless your in the pinnacle of the sport where your budget will sustain milions in R+D, im sure yours doesnt, mine certainly doesnt, and neither does 99% of cosworth owners, there just sheep.
markk there is huge difference between restrictor before the turbo which won't let you get more then 0.5 pressure differentail between sides because of critical air-flow, and restriction in pressurised part of intake system that won't stop you from running even more boost to overcome it. So comparison doesn't seem any good.
...i see Harvey is using Mikes username again ROFL
Like i said i researched and all i am saying is...std comp or 7.9-1
and 32psi held on pump fuel aint gonna cause any issues as the engine is specced to do that.....i will admit the GT35 1.06 on pump may have been pushing the comp too far if i had tried to run max boost but then i remember saying that incar on pump i would run 500bhp and then with race fuel run it flat out
Hence why now i have gone T4...the fact is std comp on optimax will run 550bhp reliably if you take the blinkers off...400bhp with blinkers on
I aint no genius which is obvious
but the people i get my answers from ARE
Regulatory resctrictor on rally/race cas is different kind of restriction then standard Cossie elbow or throttle body, or whatever of this kind. It simply imit the amount of air avaliable for the turbo - you cannot exceed critical airflow, at the same time yo can push more air through restrictions like narrow parts of the intake after the turbo, even if it will require much more boost. This makes rally engines very different story.
Mike Rainbird
mark tried advancing my car so far to the point that it started to lose power and still no det
