Has anyone got the standard ford map
Cheers for replying stu and Nick,
I would ideally like the firing angle of the injectors with revs / load. I don't know if its a full load vs rpm table, or just rpm (as the screenshots in that thread suggest).
Do you alter it in your maps stu if so what benifits does it give you, or are there few gains to be had over the standard ford settings?
Testing the future
it's just rpm vs angle for marelli ecu's as standard or running the pectel run program.
that's probably sufficient unless your chasing the last nth degree of tuning potential
Cheers nick, i've got a map table of rpm vs a limited tps map (0, 25, 50, 75 and 100 % throttle) available so if i had the original ford rpm map i could put it in accross the tps range and go from there.
muz
16-08-2015 12:57 PM
track.focus'd
12-08-2015 05:53 PM
