Alloy Rad!
Alloy Rad!
How much do they roughly reduce temps? and is it best to have one espcially when running 400bhp+ to keep everything cool and safe etc
Rhys,
I'd say it's a good thing mate.
I like the fact that the principle cooling part on the car is new, and you know its condition before you start (especially this time of year)
never had any problems with the standard rad,
some peeps have problems once they fit a 500 intercooler and the air has to go though that first,
as long as your rads in good order and the fans work, it will be fine,
add water wetter as well, and you will see 5 deg of your normal running temp,
well it did on mine and my gauge is correct,
the race cars have different rads bigger and alloy, the others looks like copper,
but they do not have fans and run flat out all the time so more cooling is needed,
yer,
i was recommended it, and i was quite unshore if it would work, but it does,
and on my car it was 5 deg lower in normal use, the bottle says 10 to 15 deg,
but i was happy with 5 deg off,
companys like demon tweeks sell it,
Originally Posted by marco polo
and they are abit lighter than the standard rad
Cool suppose every little degree helps will look into get some of that stuff too then
Plus it looks more bling in your car
Originally Posted by paulp
was just thinking what if you had a front end dink,and you had a grs intercooler,and an alloy rad that would be over 600 quids worth of damage
Originally Posted by Phil
I have a Pace alloy rad I can sell you Rhys, but I do remember Mike R telling me a *new* standard rad is as good!
07-10-2015 12:56 PM
