Aeroquip fittings
Aeroquip fittings
I'm just about to get round to doing the fuel system on TB'd car for a mate.
The fuel rail and regulator are all -6 fittings so I'll use aeroquip from the fuel rail to regulator, I will also fit a standard cosworth pump so I could fit -6 fittings to that.
Problem is that my mate will be running a full interior so I cannot run the lines from the tank inside the car.
Would you use aeroquip front to rear under the car or just stick to the original plastic pipe front to rear ?
Is there a -6 to push on pipe fitting available if I chose to go for plastic or rubber pipes front to rear ?
Thanks
James
Thanks
James
09-10-2015 07:38 PM
track.focus'd
12-08-2015 05:53 PM
