600bhp with a t4..
600 sounds like pushing it a bit, but certainly well over 500 is possible on the right spec one.
Cant see many people buying a 10 grand engine off ebay though!
Originally Posted by Bosch-Man
The Grp A touring car version of the T4 is capable of 600bhp on race fuel...apparently the cars used to run that power in qualifying!
to be fair it would be around the 550 mark but my sales guy has bigged it up a bit but. on race fuel and 2.2 bar it would be very close.will find out soon as going on paul hills dyno once i get a chance to do some miles on it .then il be putting my proper engine in then well see some big power.will post al details soon
Caraholic
Originally Posted by jhw
It might be a 'proper' t4 not a rs500 t4.
Remember Gareth Lloyd has around 600 on race fuel this does not state whether it is on race fuel or not.
In my opinion these cars would nevr have had anything like this kind of power in the cars... I just don't think the Turbos or just as importantly the intercoolers are upto it!!!!
and yes I know Rod runs a 500 cooler... but NOS has a huge cooling affect!
At totb 1 Both Derek Burleigh & mine beat it Topspeed & i ran the same Terminal on the 500m suggesting i had more Power but less grip.
Mine was running a rather lame 480bhp on the Day suggesting Gareth had less, think Mike has shown why. Yes people were claiming 600 back then makes you laugh.
Originally Posted by Turbosystems
An rs500 to4e is not a 600bhp turbo
You need a 0.83 turbine housing and a 60 trim comp wheel this was known as a to4s and are as rare as hens teeth.
.60 on compresor and .83 on exhaust?
I'll take a
weve seen 573 bhp on 8 greens 500 plenum 72mm throttle body t4 with f1 shaft and comp wheel on same spec engine as advertised al bench dynoed by tommy feild and thats corrected data anyone is welcome to ask tommy this as he is not a bullshiter.back in 96 we had 539 bhp and 487lb ft out of same spec engine just 8 greys instead of greens that was on a guy called dave hills bench dyno.that was laggy to fuck but felt like being hit up the arse by a steam train when boost came on.that 500 driven by vinny pearson took al the honors back then 0-100 in 8.8 qtr in 11.54 beat bbrs own car on fast car shoot and won the qtr shoot performance ford.luckily mapping has come on a long way since so not as much lag.the blues on row 1 are because its being run in if i ever get a chance to drive it then its going to paul hills r/r.will post power figs when done.
Mad Rod Wrote:
Lots pf myths about Gareths car cos its such a track weapon.
Rod,
Gareth's car only did 1 Top speed Run at TOTB 1 which was a sighting Run and not flat out.
He wanted to concentrate on the Handling and 500 metre runs instead.
Which he finished 1st and 2nd in respectivly !
Rod,
