JIM'S MISFIRE THREAD
#81
ok, they MUSt be different, as the size of the lobes are different (ie top to bottom) but can i find a groove? can i bollocks
there's a groove on ONE of the 4 cams tho but its not on the bearing, its on a round bit next to the front bearing (ie not the one with lobes on it)
#83
ps the one with the bigger lobes had the groove on it. from the left bank.
were just taking the right bank out now (but there is no groove on either)
#84
ok, 1 cam... big lobes and a groove.
3 cams, small lobes and no groove
maybe theyve sent me 1 inlet and 3 exhaust cams?
and no i DONT have the spec of the cams, and we're measuring with a vernier caliper
#86
standard cams back in... running problems solved
i'll be voicing my dissapointment with kent tomorrow.
i've now got 3 things im a tad worried about tho,
1) car runs lean (which i THINK is because stu adjusted the throttle stop so i reset all the TPS positions, i think thats thrown the map out! im gonna reset it abck how it was n see if that cres it)
2) OIl Pressure Gauge (which keeps playing up!) is showing lower than normal. its a cheap shit one tho, so i wanna get a proper one on there to check it
3) engine turns over very slowly, like battery going flat, alt is charging @ 13.x volts ok tho
should all be easy bits hopefully at least the engine sounds healthy again now
#90
just spoke to kent. the guy doesnt agree that i've got 3 exhaust cams.
he now tells me that the groove on the journal is only on the cosworth YB not on the V6 (so why does 1 of mine have a groove, and NONE of the standard cams do?) and that the sifferent sized lobes is to do with wear on the cam (we're talking a good 2mm here)
so ive got to bring them down and they'll do a report. however after speaking to the bloke it doesnt sound like this will be plain sailing for me
thanks kent
thanks kent
#94
Originally Posted by Jim Galbally
he doesnt want to refund me by the sounds of things.
HIM: "we only did what you asked for"
ME: "why would i ask for 3 exhaust cams"
#97
im more pissed off at the WEEK i've lost looking into this, and the cost of getting the cams fitted, refitted, and replaced. i'm quite out of pocket and wishing i'd never started
#100
Hope you can recover the costs.
I once bought a piper cam that wasnt finished properly and had to make 2 trips to get it properly finished before the cam could be fitted to my engine. I was lucky my mechanic fitting the cam noticed the cam stopper missing from inside the cam and told me to send it back.
#104
Originally Posted by James
How can you have three exhaust cams? on the picture on the other page you have two long and two short cams - sooooo you don't have three the same do you?!
He could have three exhausts cams if kent had more than one set ov 24v cams in.
#105
yep, ive got 2 long exhaust ones, and 1 short exhaust one, also one short inlet one.
well, thats providing theyre definately inlet/exhaust, as the guy form kent wasnt making himself very clear
07-10-2015 01:56 PM
DavidK
27-09-2015 03:55 PM
