f.a.o brake experts
f.a.o brake experts
hi guys have some questions about master cylinder sizes and tarox calipers
first off the easy one
can you get brake pads for tarrox 6 pot calipers from any other manufatures than tarrox themselfs
and the second one is i am fitting a new brake system to my gte a twin master cylinder unit that replaces the master cylinder the master cylinder sizes at current are
.70
.625
go these sound like they are right for my astra
i am sorry but dont have the first idea what the numbers even mean
so any help would be much apreciated
.70
.625
Resident Wrestling Legend
the numbers are the bore sizes for the cylinders
when i put the pedal box on my 3 door i had the same problems and even the people who were supposed to be selling them didn't help that much (mentioning no names because they have been faultless ever since)
if you are going for the adjustable pedal box assembly then you want the bigger one to do the fornts and the smaller one to do the rears
be warned that you will more than likely need to be plumbing in a set of servo's ebcause without them, you really do need legs like tom platz to be able to stop the same way you would before
after that it's trial and error to get the system set up to how you want it to behave, but make sure you don't go totaly loopy with it and send it the wrong way, you want the bias to be towards the front or you will be swwapping ends like torvel and dean
also, when you set them up you will find that the bar goes across and, with no fluid in the system, you wil need to figure out which way to set it up so the biger cylinder get the front brakes and the smaller one gets the rears
from what i can remember (this is going back probably 10 or 12 years now) the shorter the bar the more effort you will be providing
so adjust it so that the shorter section of bar is on the .70 cylinder and the longer is on the 0.625
i'm sure you can get bigger ones but don't quote me on that
OK,when I fitted mine I was told by a reliable source who did rally preperation that the largest cylinder .7 was to work the front brakes and the smaller was for the backs.So thats the way I connected mine up.....................And the brakes where cr*p!! So I rings up my reliable source and tell him this,so he then tells me to swap the cylinders over,.625 for front and .7 for the back,and hey,the brakes where brillant!! Also,unless youre very weak (like those people who want to fit powering steering on a RST ) you will have no problem pushing the brake peddle.All the best,Micky
well thanks for the info lads atleast i have the right cylinders
i thought the .7 was for the front as they need more pressure so are bigger to send more to the front brakes :S
Are you running a servo ?
The .7 one as mentioned above should be on the front, but that really depends on the lengths of the piston rods too.
You can change the characteristics within a bias box by adjusting the length on the piston rod, by altering the balance bar, or by using different sized cylinders. If you dont know what your doing you can easily mess it all up, but get it right and it will be superb.
As for the pads - yes you can
Micky sounds like your rod lengths were wrongly set up
You'll get more pressure from the .625 814.87 psi compared to 649.61 psi for the .70 and that should be the front master cylinder....on all rally cars ive ever built we use .625 for the front and hand brake......70 or .75 for the rear....rod lengths should be equal in an ideal world but sometimes do need a tweek..
Regards
Ian
Regards
Ian
where can i get teh pads from as tarrox's prices are a little special lol
Originally Posted by 89XR2
I would get someone who knows what they're doing to set up your initial brake balance etc or it could all go horribly wrong for you.
brilliant idea
can you tell me anyone that does this ???
No But on the plus side i'm sure there must be someone who does know what they're doing! Somewhere that sets up rally cars or the like? I'm sure Martin at Reyland would be able to do it or someone similar?
There's some interesting stuff on here http://www.zetecinside.com/xr2/brakes.htm , might be able to help you understand it a bit more
i thought that might be the case as if you read 4 posts up i had already said i want it set up properly and how does it
Tony,
Rod length only determines how much travel is in the pedal, longer rod length (shorter travel) could make that cylinder operate before the other, so potentially the back brakes could lock before the fronts operate.....i'd always start with equal rod lengths and let the bias bar decide on bias front to back....and in my experience of competition cars ive never seen many that dont run a .625 on the front.....
At the end of the day its about personal preference but the majority of the braking effort wants to be on the front......
Ian
Ian
brilliant idea
Ian
brilliant idea
Ian
or does anyone in the south fancie a go lol
As your running no servo then yes the .625 front will work better (I was presuming you was leaving it on). Again thats presuming you want a firm / no travel pedal feel.
Set it up, dry build with the rod lengths equal as Ian says, and with the bias wound about 80% on the front. Fill with fluid and bleed as normal then go find yourself a big open space and see how it performs. Be very careful at this point. If you have set it up wrongly the car will chuck you in all sorts of directions (which is fun) lol.
Dont expect to get it right first time - but do have a go yourself before calling on the experienced, that way if you need to adjust anything in future you will have half an idea what to do.
For pads take your existing pad somewhere like a motorfactors (when they are quiet) and ask them to match it up. They should have all the reference books to do this. That will give you a car and model where it comes from, then just order a competition pad for that vehicle.
DavidK
27-09-2015 02:55 PM
