how many cables are in use on a s2 internal swirl pot?
i have the cables that plug together but the rest are cut and i can only find two? is this all that is needed for it to fuel? cheers
i have a loom that has been cut, and the the thing under the seat i thought was the swirl pot the cables have also been cut? i have 3 browns and a black and red from the tank but the loom only has 2 cables that i can find, ive followed it back? is this all i need?
wheres it been cut?
the fuel tank sender will have 3 wires i think and the thicker 2 cables black/red and brown will be the duel pump wires
the others 1 is for you sender for the gauge on the dash
the other two i think are for your fuel computer if you have one there should also be a connector under the seat which the fuel computer loom goes into
muz
30-09-2015 08:29 AM
