Tyre pressure monitor
Hi everyone, I fitted a Tyre pressure monitor to my BMW a few weeks ago and found it to be an excellent bit of kit I don't know what I did without it. It will monitor your tyre pressure and tyre temp
Its Ideal for high speed driving not that I do any of that
Once fitted You set the Tyre pressure to what you want and it then monitors each tyre every few seconds when driving.
Should the pressure start to go down a buzzer will sound and a light is displayed on the control panel. The same happens if the temp exceeds your desired setting. You get an extra transponer to go in the spare too. So for safe driving and track days I would recommend this Inexpensive bit of kit.
Originally Posted by Jim Galbally
got any more info ana price? sounds like somehting i'd be interested in
Originally Posted by 89XR2
Had a look at one of these the other day. How does it measure the tyre temps, does it have sensors attached to the alloy inside the tyre or something similar?
Ive seen this kit Today, very impressive backlit LCD display that constantly monitors both tyre pressure AND temperature live, at all times, so will warn not only of a tyre losing air, but alos one thats delaminating, as they get very hot indeed. Could also be an aid to set up car weighting as you can constantly monitor your tyre temperature's... interesting to see which gets hottest under what conditions.
VERY impressive kit indeed
Bring on teh pictures!!
...and the prices
Steve
No1 Blower.
Sounds like a good bit of kit for track days.
I suppose it is a nice extra gadget for your drug dealing, gun shootin, getto blasting pimp ride.....
THIS IS STU's RIDE
THIS IS STU's RIDE
Originally Posted by NUTS RuS
Seen them in the Tweeks catalogue My Laguna has something similar as standard Not that I ever look at it
Thats why I dont look at it too often
To be honest they show on the dash display at 30psi most of the time, and the gague I use says similar. Its a diesel too so it never goes fast enough to warm them up above that
Im sure the ones in the Tweeks bible were more expensive than £235 tho'
THIS IS STU's RIDE
THIS IS STU's RIDE
Im sure the ones in the Tweeks bible were more expensive than £235 tho' [/quote]
That's because I sell top products at Good prices and have lower overheads than Tweeks
...and the prices
Steve
sounds good, but for 235 i could get myself 1 1/2 pistons
THIS IS STU's RIDE
THIS IS STU's RIDE
