Xbox 360 Help
Xbox 360 Help
Hi All,
I have just bought a game "The Outfit" but every time I try and load it it says "this games doesnot support Pal-50, please change to Pal-60. To change your setting, in system, select console setting, display. Well been there and altered everything but to no avail.
Anyone else had this problem and how do you sort it
Thanks
Smudge
Thanks
Smudge
Smudge does your telly support Pal 60?
I bought DOA and thought my plasma would cope with 60 Hz but (logically ince its pretty much new) but it didnt.
Check the manuall for the telly though because if your picture is just changing to a blank screen for a bit then reverting then thast your problem mate.
Hope that helps
Pete
Hope that helps
Pete
I got the 360 connected to my plasma HD and when it the 360 first boots its states its 1920x1080x60hz. When I got DOA i had to change nothing as it worked striaght away, doing my head in now spend £40 on a game I cant play
Weird.I downloaded the demo of this game and it wouldnt work,said to change settings to 60hz but DOA4 worked no problems
Had to flip the switch on the HDAV cables to standard TV and it worked OK,well..apart from the crap graphics you get with standard
Dunno mate,a bit crap if you cant play it on HD
Switch x box off, on the HD cable switch to normal and then adjust in the 360dashboard to 60hz. Switch back off then swicth back to HD on the lead and it worked.
The Outfit is ok not a great game, Ghost Recon 3 is awesome but on hard level is immpossible
