4x4 gearbox and diff question
Old Mar 15, 2006 | 08:50 PM
xr4x4rs's Avatar
xr4x4rs
Default 4x4 gearbox and diff question
there was a post not so long ago about about different fiffs
now my question is
my car runs the 3.6 diffs
im going to be using a gearbox out of a 2.9 xr4x4 which uses 3.9 diffs
will i have any issues
or will i need to use the 3.9 diffs
totally confused on all this
thanks
Old Mar 15, 2006 | 09:04 PM
markk's Avatar
markk
no pal, the box will be fine, its only if you run differant ratios front and rear.
e.g, my car will run a 4.55:1 in the rear, and a 3.64:1 in the front, so will need to adjust the step offs to suit a ratio differance of 1.25:1 between front and rear,
your setup 3.64:1 rear , 3.64:1 front is 1:1 equal diffs, therfore wont need any adjustment as the 2.0 = 3.9:1 and 3.9:1 so the step offs will be 1:1 std ratio.
does this make sence ?
Old Mar 15, 2006 | 09:21 PM
gearboxman's Avatar
gearboxman
Haha!
Gotcha!
You think you're so smart.....
you spelt sense wrong
Old Mar 15, 2006 | 09:24 PM
markk's Avatar
markk
Originally Posted by gearboxman
Haha!
Gotcha!
ahhhh bollox !
(darth vader voice on) obi wan has taught you well (darth vader voice off )
Old Mar 15, 2006 | 09:27 PM
gearboxman's Avatar
gearboxman
Old Mar 15, 2006 | 09:30 PM
markk's Avatar
markk
have you got any spurious step off gears/chains knocking about bernie ?
i think ive got mine sorted with a 32/24 should be ok, just wonderd if you have anything else ? 31/25 ???????
Old Mar 15, 2006 | 09:39 PM
gearboxman's Avatar
gearboxman
25/31 is closer at 1.24:1 than the 24/32 (1.33:1)
Sorry mate no.
Old Mar 15, 2006 | 11:22 PM
JohnnyB's Avatar
JohnnyB
as long as you have the same diff front and rear no problem.
else VC will over heat and fail and maybie rodger the plannet gear as well then only RWD
Old Mar 16, 2006 | 11:24 AM
xr4x4rs's Avatar
xr4x4rs
ok
so as long as both front and rear diff are the same i shouldnt have any worries
whats the better diff to use as i have cjoice of both at the minute
3.6 or 3.9 and why would it be better
thanks
Old Mar 16, 2006 | 11:29 AM
ian sibbert's Avatar
ian sibbert
I thought the XR4 x 4 and cossie had the same final drive ratio....3.62:1....
Didn't think the XR4 x 4 was on a 3.9.....
3.9 will give you better acceleration, less top end....
Old Mar 16, 2006 | 11:38 AM
xr4x4rs's Avatar
xr4x4rs
the 2l models came with different diffs than the cosys or 2.9s
so think these are 3.9 then i thought they were 3.6 lol
not to bothered about top speed so ill stick to the 3.9 then
thanks
Old Mar 16, 2006 | 05:07 PM
PAUL S's Avatar
PAUL S
the 2.9 came with 3.6 diffs as per cosworth and has the same box ratios as a cosworth - just a different case
the 2 litre came with the 3.9 diffs but different ratios to a cosworth but in the same case as a cosworth
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
