ERST rear disc conversion plates...
I'm sure someone a while ago had a CAD pic of what size they should be, anyone got a link to it or know who has?
Along the same lines do these look any good?
http://cgi.ebay.co.uk/FORD-ESCORT-MK...QQcmdZViewItem
Seen these go pretty cheap from the same guy before.
Baby Cheesus
wes, i think so mate as its just the caliper thats wider ie you stick 4x4 calipers straight on a 2wd with the 4x4 discs.
anyway, with the caliper brackets etc, what hubs do you use or do you need to get your drums turned down to act as the hubs, i think thats what they used to do...
Caraholic
Just in case you can't be bothered to make them . All on the shelf complete with fitting hardware (all bolts etc). Please note that if you have 2wd callipers, you need 2wd discs and if you have 4x4 callipers, you need 4x4 discs.
http://www.randbmotorsport.co.uk/sho...p?ProductID=68
1.6 Escort Mk4 should have a 2 piece rear drum, just knock the hub part out by screwing 4 bolts in, putting it on the ground, and jumping on it.
Clean up all faces thoroughly, and while you are there, remove the crappy load proportioners
