Mid Rebuild and more questions. . . . . . ;)
(For a stage 3 saff coz, 200 block, 6 studs)
Does anybody know how you torque down a head when you have 6 studs and 2 bolts, because the bolts are obviously stretch bolts and the studs arnt
- and to what torque?
Plus what are the spark plug gaps, crank sensor gaps and the phase sensor gaps.
Oh and what torque setting for the cam bearings.
Dont want a lot do i !
Thanks in advance
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
Thanks in advance
![](https://passionford.com/forum/images/smilies/smile012.gif)
Team HOTHOT!
If you have 6 studs and 2 bolts i'd be worried - very worried
torquing down is in the normal order, and to the normal torque settings in a 3-stage tightening sequence, starting from the middle and working outwards in a zig-zag back-to-front fashion
plug gaps, if using coilpacks - 0.8mm, if using standard dizzy, 0.65mm
CPS gap - 0.2mm to 0.3mm
Phase gap - 0.3mm to 0.4mm
torque setting for camcap covers is 12Nm off the top of my head
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Oh and has anybody had to grind a socket down to do the head nuts up? or does the head normally get machined .
Not looking forward to grinding me Snap-On stuff
whats studs are you usings
as i know that arp say dont go by fords torques setting and to go by theres
i asked this at a place up the road from a skyline tuners and the answer i got was each bolt manufacture will have a different setting to a ford one
so go by what the bolt manufacture recommends for torque settings
what do you mean grind a socket down?
Team HOTHOT!
grinding the diameter of the socket down so that it fits in the recesses in the head, this is due to the long stud bolts being a larger diameter than ford bolts
If you are going to grind one down, go buy a high quality impact socket, and then get it turned down on a lathe
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
