Cossie uprated breather kits
#42
Originally Posted by NORTH YORKS RS SPARES
Stu
Please explain ??
It works in exactly the same way as the G/Goode system exept i fit the tank on the left and extend the pipes
Paul
Please explain ??
Paul
Mine breathes bothe sides of the block into top of breatherpot, then from the top of the pot vents to atmospehere
at the bottom of the breather pot I have a return to sump (bottom of the sump below oil level)
If you are returning to sump via breather hole this isnt ideal IMO
#43
Damo
Mine also vents to atmo via the mirror tank, and returns to sump below oil level from the breather pot same as yours
Top and bottom is i am very very happy with how mine works as i have never had a oil surge problem even under harsh driving and i have never sufferd from oil leeks etc
Paul
Paul
#47
Damo
Paul
Paul
#48
i think the breather system on my car is a right mess
ive not touched it since i had the car, as i dont know a lot about it..
but it has the original kidney box, and a breather tank too..
dont seem quite right to me
would love to know more
#49
PassionFords Creator
Thats actually a good mod IMO, it has an oil seperator from the start, so can help with oil overload on teh inlet side.
#50
Get on That!
Rite following these post now what are u meant to do with the L bend that fits into kidney box and the small red filter when u fit these oil breather kit?
Also from the red filter u have a pipe that feeds into the inlet and then a T to a valve of some sort? (that ticks away when u turn ignition on)
When u fit lets say a Bailey kit is says take the pipe straight from top of Kidney box(ditching the red filter and pipe work) and gives u a blank for the Inlet manifold what are u meant to do with the the small pipe that feeds into the Valve (that ticks when u turn ignition on)
Can u just let this vent to Atmosphere or do u pipe it into the vacuum nipples on the inlet manifold
#53
Get on That!
have added inmore detail your car might not have had these parts on if u already had oil breather kit fitted
The little valve thing sits on passenger side chassis leg in engine bay under the ABS unit
If i remember rite this valve has something to do with the fuel vent pipe i think?
jonfoc
16
11-09-2018 05:35 PM
