CVH experts help please!!!! (quick question)
Old Mar 9, 2006 | 09:38 AM
Mk3Ghia's Avatar
Mk3Ghia
Default CVH experts help please!!!! (quick question)
Im building a CVH (n/a) at the moment and have noticed a 'quirk' I need you guys to tell me if this is normal or not.
Basically the main bearing shells do not seem to line up! looking down on the engine (sump side up, crank horizontal) the shells are mis aligned by about 2mm.
The crank moves freely despite this.
I have another CVH bottom end (looks like an earlier one) on which this doesnt happen when using the same shells.
Im told by the shop that got me the shells theres only 1 type for 1.6 CVH??
What the phuck? Is this normal?
Old Mar 9, 2006 | 09:49 AM
Rick's Avatar
Rick
there are 2 types of shells for the cvh.
On one type, the earlt type, the shells have grooves all the way round. On the later type, there is only grooves in one of the shell halves. The block is matched to this. However, it doesn't matter, as long as the oil holes are aligned.
Old Mar 9, 2006 | 10:35 AM
Mk3Ghia's Avatar
Mk3Ghia
Thanks for your reply bud.
I think I have the wrong shells (early type for later block) As orginally I did have an early block, but mid build it was scrapped for a better late one.
Like I said the orgianl early block was fine with these same shells. It was just the fact the muppet I bought them off said there is only 1 type of shell for the CVH that made me wonder.
Old Mar 9, 2006 | 02:35 PM
Rick's Avatar
Rick
most people think there is only 1 type of shell, i think they prob changed it when they changed the crank/pump.
Old Mar 9, 2006 | 03:21 PM
gary scott's Avatar
gary scott
The big end shells are the same but the main shells on early blocks have a casting problem and the main shells have a +.4 on some of them ( Makes them wider I believe??).
So the sizes are (say?) standard +.4 and 0.25 oversize +.4 and so on. This would explain why they would sit out of line.
I had this problem with one of my old engines and the shells from ford with +.4 were mega expensive.
Have a look on one of the old shells and see, it should state the size and +.4
Hope this helps.
Mk3Ghia's Avatar
Mk3Ghia
ermm so will I run into problems with my early crank\pump and late block as well??
Old Mar 9, 2006 | 03:25 PM
Mk3Ghia's Avatar
Mk3Ghia
only thing on the old shell is:
s596sa
STD
Dont tell me my shells have the herpe clapp as well?
Old Mar 9, 2006 | 03:39 PM
gary scott's Avatar
gary scott
Not all early blocks have the problem I described, just something you could check that was all. You could just simply have been given the wrong shells.
The early crank will be fine in an late block provided you have an early type oil pump to suit the crank.
Oh and the shells are the right ones...
Old Mar 9, 2006 | 04:01 PM
Mk3Ghia's Avatar
Mk3Ghia
crank and pump defo match, I was quite aware of that before purchacing
Still not sure where I stand as far as shells are concerned Just to recap:
--- Im pretty sure I have a late block.
--- The shells I have fitted my old block perfectly. This block was chucked due to cracked oil pressure switch hole.
---The same shells now sit wanky in the good (late?) block.
I think I will invest in the later shells (only one groved) and see if they sit better.
Thanks for your help gents, more gems of wisdom are welcom if anyone has any
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
