who supplys a 4 tooth tdc pick up pully for cvh?
need the pully and sensor mount for the cossie conversion as i have made one it works but its not the most steady bracket and i dont trust it.
would be a help to if i could get hold of the phase sensor brackets for the cam pully type so i dont have to mod the dizzy
Spanner monkey
i have a modified 1800cvh crank pulley, moddede trigger ring, moddede crank sensor bracket, sensor, alternator bracket and alternator pulley ready to go!!
Ask me a question!
A cut and shut dizzy, or molested one as above is not the best way to trigger your ŁŁŁ engine..
How much is a cut and shut dizzy gonna cost?? How well will it work. How long to get one made. will it work?>????
A cam sensor trigger system only costs Ł70 depending on what engine its for i.e 8v or 16v
If you have to use a dizzy for value for money as you cant afford the coil pack conversion. The dizzy should look like this and have NO CONTROL over the management system
If you want to use the best setup available it would be the same as the WRC engines with a Cam sensor
This system has no moving parts to wear or fail..
Over X amount of time the sensor will need to be changed. But i know of cossies with the same CPS it came out the factory with over 15 years ago still running without any issues.
If you want to do it properly then fit a coil pack. But without a cam sensor you will struggle to make a coilpack work 100%
If you have any questions please ask.
Regards
Jano
Regards
Jano
Ask me a question!
Gadget his talking about the phase sensor.
He wants a bracket that will not vibrate or cause any type of problems once fitted
The same as what is supplied to many tuners in the UK from us
Regards
Ask me a question!
Re: who supplys a 4 tooth tdc pick up pully for cvh?
Gareth, we are talking about:-
Sorry for the slight lack of wording then..
Without a cam sensor you will struggle to make a coilpack work 100% on a CVH/ZVH/Zetec
Is that better
Spanner monkey
Regards
Is that better
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
