question about amal valve
On my cossie, i had removed my airbox to put a big group a cone.
In the pass, i had removed the amal valve, and i had put a bleed valve.
After, i had check my boost preisure.
Few month pass, and after i had readen some technical advice on passionford, i decided to fit my amal valve again.
But after, the preisure increase dangerously (more than 2 bar), so, a friend tell me to put something in the amal connector (which go to athmosphere now because the airbox was removed) to reduce the size.
What do you think about that and you, what are you doing when you remove the airbox ???
Football Cwazy
probably yes, first check the connections to the amal valve are correct
you will see thre markings on the amal valve:
W - this port is for the hose that comes from the actuator ( W for wastegate )
C - this port is for the hose from the turbo compressor housing ( C for compressor)
R - this port is for the hose that Returns to the airbox ( which will now be left since you have removed your airbox )
Originally Posted by Stu @ M Developments
No, your friend is correct, the airbox pipe was calibrated.
If your boost is too high and all pipes etc are correctly fitted, restrict the pipe that goes to the airbox until your boost is back where it is required.
But, how can i know if i need to restrict the pipe or change the preisure on wastegate ?
