Sensor question
Old Mar 5, 2006 | 09:41 PM
pee vee's Avatar
pee vee
Default Sensor question
What is the sensor that screws into the YB Block,
under the turbo, just above the breather/sump pipe .
Knock sensor?
Also, do all 4x4 cos have this?
took my engine out today, and the wire that goes to that sensor
had broken
mine is a Red top engine,, NO lambda, so i didnt think it would have a
knock sensor If thats what this is.
Old Mar 5, 2006 | 09:48 PM
SPADGE's Avatar
SPADGE
What breather/sump pipe do you mean on the turbo side mate? The oil return from the turbo??
Old Mar 5, 2006 | 09:54 PM
rstoughy's Avatar
rstoughy
If its the Knock sensor M8 it should have a cable that runs right along the Turbo side of the block, round the front and up to a plug beside the Dizzy. It should be on the same bracket as the TDC sensor plug.
Old Mar 5, 2006 | 09:57 PM
pee vee's Avatar
pee vee
thanks guys
SPADGE yes turbo side mate. it is a knock sensor
pink thing
plugs in next to TDC sensor.
i'll be needing a new knock sensor then
how much that gonna cost me !?
Old Mar 5, 2006 | 10:04 PM
pee vee's Avatar
pee vee
odd
i cant see them listed in shops etc
are they even used if the ECU has been chipped?
Old Mar 5, 2006 | 10:06 PM
rstoughy's Avatar
rstoughy
Ive seen the odd one for sale on Ebay but i always get my chips set to run with out it.
Old Mar 5, 2006 | 10:23 PM
pee vee's Avatar
pee vee
ok thanks mate!
might have to ask a breaker on here!
Old Mar 6, 2006 | 08:14 AM
GARETH T's Avatar
GARETH T
depends on what software was used for the remap
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
