Anyone playing bootleggers?
Warning: mysql_connect(): Can't connect to MySQL server on 'db.bootleggers.us' (111) in /www/config_files/mysql.inc.php on line 28
Could not establish a connection to the database server.
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /www/config_files/mysql.inc.php on line 59
You could not be logged in! Either the username and password do not match or you have not validated your membership!
Please try again!
keep getting this
Please try again!
keep getting this
Originally Posted by twitchyrear
Originally Posted by Adrian
Looks like it cant access the SQL Database.
All of our info is held in a database. The error above says it cannot connect to it. This may be due to it not being there (deleted for a reset) or that the server running the SQL side isnt up and running so therefore cannot connect to it.
As for up and running, no idea. Depends if the BL webmasters know about the error.
Did Someone Mention TUV
Think there has been a re-set guys. If you click on register on the home page then it says you can enter your old log on info
Or does everyoen already know this?
Bootleggers is currently offline and has been since late on May 2nd.
So far I have been unable to find out why BL is offline and thus I cannot give you guys a time on when it will be back online.
If I find out anything else, I will post it here, so check back periodically.
Thank you,
-LP
Thank you,
-LP
""If you were registered prior to the reset, you can fill in the form on the bottom of this page with your old information. Doing this will allow your new username to keep the sign-up date of your old username""
it is
it is
was anyone playing when it actually went off??
FULL MESSAGE ON BOOTHELP
Bootleggers Status: Update 2
As far as I have been able to establish, Bootleggers has been taken offline deliberately by BSF2000 and is not as a result of BL being unable to connect to its respective databases. As yet I have not found out what is being done to BL while it is down.
Thank you,
-LP(lordpringle)
Thank you,
-LP(lordpringle)
NEW MESSAGE ON BOOTHELP,NO RESET
Bootleggers Status: Update 3
As far as I have been able to establish, Bootleggers has been taken offline deliberately by BSF2000 and is not as a result of BL being unable to connect to its respective databases. As yet I have not found out what is being done to BL while it is down, other than there will be no reset at this time.
Thank you,
-LP
Thank you,
-LP
