turbos....how to pick one.... any1 know anything about VNT?
Old 28-02-2006, 03:54 PM
  #41
Originally Posted by stu21t
well i guess i need to speak to some mappers and turbo suppliers a bit more before going ahead.
if an external wastegate was fitted then wouldnt that limit the boost it would produce so not much fear of it spiking
also a pop off valve could be fitted at 1 or 2 psi above the desired boost level for safety,
plus if it was mapped for vanes closed but they opened then surely the egts would go down and the ecu could react??? same vise versa to
"normal" cossie doesnt monitor EGT.
It is NOT a change in boost im worried about, its a change in the restriction on the exhaust side of the engine which would allow more airflow at the same boost level, which would result in a lean out.
Basically if the vanes open at a point its mapped for them closed and there is no way of the ecu knowing about the change then you would be looking at the same issue as changing from a T34.48 to a T34.63 without having a remap.
Old 28-02-2006, 04:13 PM
  #42
stu21t
stu21t's Avatar
but wouldnt egt register this change?
if the vanes are closed then the egts will be higher due to coming through a smaller hole. wont they?
i will be using non std management that can moniter this.
Old 28-02-2006, 06:37 PM
  #43
James
James's Avatar
wouldn't a map sensor moniter it? as the position of the vanes reflects amount of boost?
i've come accross loads of these with the vanes stuck, and as far as i've seen it's almost always cars that are low mileage/owned by a granny. so the car isn't revved as high thus the vanes don't move to they're full extent thus sieze.
Old 28-02-2006, 06:47 PM
  #44
no, if its got a decent wastegate the map wont be effected, but the amount of air consumed is still going to be.
like i said, its the same as a T34.63 and T34.48
same boost = different airflow
Old 28-02-2006, 07:46 PM
  #45
JohnnyB
JohnnyB's Avatar
liamT74
23-09-2015 10:24 PM
Alloy wheels and ICE for sale
19-09-2015 07:50 PM
Alan G
17-09-2015 09:39 PM
STAFFY OWNER
13-09-2015 08:59 PM
oilman
Trader Parts for Sale.
04-09-2015 09:34 AM
Quick Reply: turbos....how to pick one.... any1 know anything about VNT?
