Sponsored by:
Sponsored by:
how to remove the wire from a wire rang block .
Old 27-02-2006, 05:06 PM
abdr500
abdr500's Avatar
Default how to remove the wire from a wire rang block .
.had a block wire rang.a few years ago and the wire is looking a bit flat its only welding wire that ther how do u get it out any tips
Old 27-02-2006, 05:22 PM
abdr500
abdr500's Avatar
up
Old 27-02-2006, 05:45 PM
ellicoss
ellicoss's Avatar
Done mine this weekend all i done was knocked it out with a small screwdriver but you will find its not welding wire as welding wire is copper coated steel you need pure copper as welding wire will not squash down and will not let the head seal hope this helps
Old 27-02-2006, 05:57 PM
GARETH T
GARETH T's Avatar
ellicoss
you dont want the wire too squash, they are there too increase head gasket pressure
Old 27-02-2006, 06:05 PM
rapidcossie
rapidcossie's Avatar
you rang my lord
Old 27-02-2006, 07:07 PM
abdr500
abdr500's Avatar
so how do you get the wire out then .i know how it works so .just need to know how to remove or best way to
Old 27-02-2006, 07:40 PM
Alvyn
Alvyn's Avatar
find the end of the wire USE a scalpel type screw driver and tap it gently with a hammer
Old 27-02-2006, 07:51 PM
abdr500
abdr500's Avatar
Old 27-02-2006, 08:22 PM
Billabong
Billabong's Avatar
Are they complete (i.e. no end)? They *may* be Wills Rings??
....Or was the smiley for a 'why didn't I think of that?' ??
Old 27-02-2006, 08:24 PM
abdr500
abdr500's Avatar
Billabong
ther is a littel gap but i cant get them out
Old 27-02-2006, 09:21 PM
Alvyn
Alvyn's Avatar
Billabong
then YOUR not trying hard enough
Old 27-02-2006, 09:32 PM
Mr RS500
Mr RS500's Avatar
we used this system about 10 years ago with grass track cars and scrapped it as it didnt work ,,im amazed people still use it today !
Old 27-02-2006, 09:43 PM
dave cos4x4
dave cos4x4's Avatar
supposed to be not worth doing as there are proper gaskets now instead.
Old 27-02-2006, 09:57 PM
abdr500
abdr500's Avatar
it worked 100% for me car runs 2.5 bar and never blown a head gasket just a freshen up realy
Old 27-02-2006, 10:43 PM
PGT
PGT's Avatar
my engine had these and i couldn't get them to seal properly.
firstly if the grooves in the block are not perfect then it wont work anyway. secondly there will inevitably be a gap where the wire ends meet. gasket keeps blowing.
finished up machining the block to get rid of them (30 thou) and using different pistons to get comp correct. avoid at all costs!!
Old 27-02-2006, 10:54 PM
TiB
TiB's Avatar
If done correctly it is fine and works very very well,
if you've had them before people and had problems i think you would do better looking at how it was done rather than the actual idea itself?
Lee
Old 27-02-2006, 10:56 PM
bud-weis
Football Cwazy
bud-weis's Avatar
Lee
Old 27-02-2006, 10:57 PM
rapidcossie
Lee
AVA have wire rung a good few high power cossies now without any probs
my engine is wire wrung and im sure martins will be too
Old 27-02-2006, 11:05 PM
TiB
TiB's Avatar
My old saph was too,
37psi plus 100shot of gas and it never gave any problems for the 25000miles of hammer i gave it.
Old 27-02-2006, 11:07 PM
TiB
TiB's Avatar
Old 28-02-2006, 06:42 AM
Alvyn
Alvyn's Avatar
[quote="pgt"]my engine had these and i couldn't get them to seal properly.
the ONLY way that could happen WOULD be if the person doing the job DOESN'T know what he/she is doing m8!
YOU CAN NOT USE A METAL TYPE HEAD GASKET WITH A BLOCK THAT'S BEEN WIRE WRUNG DUE TO IT NOT BEING ABLE TO SEAL
Old 28-02-2006, 07:09 AM
Mr RS500
Mr RS500's Avatar
Tib
You must just be lucky as everyone i know who had this done had big problems with it ,I raced cars for 7 years so new a lot of people ( inc myself ) who payed out a lot of money to have this done and didnt even get a full season before it destroyed the head and block of there engines .
How many motorsport people ( and i mean proper motorsport people) not them who think 2 blasts up a strip is motorsport still use this ???
Paul
Old 28-02-2006, 10:13 AM
PGT
PGT's Avatar
well... that comment was mine and you're right i didn't know how to do it properly. but thats the point, why not just use a decent gasket and bin the whole concept of wire rings
Old 28-02-2006, 11:58 AM
Alvyn
Alvyn's Avatar
well... that comment was mine and you're right i didn't know how to do it properly. but thats the point, why not just use a decent gasket and bin the whole concept of wire rings [/quote]
so because YOU didn't know how to do it properly that makes it a crap idea
I've known many people that have and still do use this dependant on which application the engines being used for!
decent head gasket??? name me any make of gasket that IS 100% fail prove!
Old 28-02-2006, 05:57 PM
abdr500
abdr500's Avatar
all sorted new wire in block just need a hammer and screw driver
Old 28-02-2006, 06:58 PM
TiB
TiB's Avatar
Originally Posted by NORTH YORKS RS SPARES
Tib
Paul
We have done 5 now and all 5 are perfect and all running higher spec than a standard gasket should allow so its been well worth doing, and only costing 30 quid its been very good value,
my saph's spec with the gas on was more than some wrc spec gaskets seem to be able to handle too.
Anyway its horses for courses as they say and i and anyone i know thats done it have been satisfied with the results
Old 28-02-2006, 07:46 PM
Mr RS500
Mr RS500's Avatar
Tib
Just goes to show . yours is a well proven car and you are happy ,
As for grass track cars i suppose they just demand to much from this system
Paul
Old 28-02-2006, 08:06 PM
marco polo
marco polo's Avatar
Hi Peeps
I had a wire rung 200 block yrs ago with grp a gasket (yb 0611)
when i was on the greens i did 38,000 mile in 5/6 yrs which included track days ..1/4 mile days and general road abuse
never had a problem what so ever
there is better things out there for the cossie now like the wrc gaskets or cometics , but with these you have to make sure the block and the head is totally flat (slightly skim the block and head job done )
marco
Old 28-02-2006, 08:16 PM
Staffi
Staffi's Avatar
Mines fine aswell
Old 28-02-2006, 09:04 PM
TiB
TiB's Avatar
Originally Posted by marco polo
Hi Peeps
marco
To be honest.. if history is anything to go by i've had more reliability from wire rung block than anything else and if i had the money to experiment i'd like to give it a go on my current engine
Old 28-02-2006, 09:20 PM
marco polo
marco polo's Avatar
lee
i don't think you will have a problem to be honest , it's just when the wrc gaskest was made (mountune)rally and race engine builders went this route instead ( instead of the wire ring )
i know yrs ago that all the race team use to use wire rung blocks
thats was the only way at the time keep the head gasket in place with out it popping and the other route was coppers rung block you had the choice of 2
but just because something comes out that is newer doesn't mean that old stuff is not as good
Marco
Old 28-02-2006, 09:39 PM
TiB
TiB's Avatar
I know what your saying but i'm just wary of the standard gaskets fire ring actually being a strong enough metal to withstand the extra heat that the nitrous gives??
this was my last metal gasket, i'm not saying it was gasket failure alone as i think it was something else that caused it to go but you can see the way the gas eats anything in its path lol
Old 28-02-2006, 09:50 PM
Wire rings are like Coopers rings..FINE if everything else is absolutely spot on...if not then big money...crap idea to use nowadays with the likes of cometics etc....my block has had the wire rings machined out...SCS done this....My experience with coopers was disaster..LOL.
Old 28-02-2006, 09:51 PM
Tony Ryan
Tony Ryan's Avatar
Ive had 2 wire rung HT racing engines in 2wd Cars, both on 205 blocks , both were fine and ran a pinto or std cos head gasket up to 2.0bar . As soon as i added a T4 tho , all fkin hell let loose , the wire blew out the side of the block , destroyed the head and dropped valves into pistons , big mess ! Long studs and Coopers rings or a WRC gasket now !
Old 28-02-2006, 10:43 PM
markk
markk's Avatar
to me its an age old idea that was the best that could be done at the time, the wires were lifed of a good power motor , only ever seen 18months work out of one in road trim, in race trim , i wouldnt even entertain it, ever.
as for a gap ? WTF - there is no gap if there done properly.
Old 28-02-2006, 11:08 PM
dumped
dumped's Avatar
Never had a problem with them on my old engines at high boost/ nos whatever Dont think my new engine is using them though as Ipaid through the nose for an expensive gasket lol
Old 01-03-2006, 10:26 AM
PGT
PGT's Avatar
so how do you join the ends of the welding wire together to get rid of the gap?
Old 01-03-2006, 05:44 PM
markk
markk's Avatar
you need to chamfer the edges pal, so that the wire ends lie together, one underneath the other
original
30-01-2022 08:20 PM
Bailes1992
03-09-2015 02:17 PM
29-08-2015 08:16 PM
jdsjojo
26-08-2015 10:09 PM
Quick Reply: how to remove the wire from a wire rang block .
