General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
10 splines is for the group A Getrag box (normal Cosworth is 23 spline) - it will fit a YB with the correct flywheel - Burtons sell the flywheel or Cambridge Motorsport also had them in for £100
Give me some prices for the clutches. And do I need some special flywheel for the single plate or the standart is fine?
You'll need a flywheel that suits the clutch , sounds like steve Kaliber cossies single plate could be a way to go as my twin plate takes a different flywheel pattern .
You'll need a flywheel that suits the clutch , sounds like Steve Kaliber cossies single plate could be a way to go as my twin plate takes a different flywheel pattern .
no again you need a basket and flywheel as the single plate i have is 7.25" you also need to take note of thrust bearing edges as there are 2 types round and flat depent again on basket teeth
