Electrical experts....Another question....
Old Feb 22, 2006 | 07:32 AM
CosRush's Avatar
CosRush
Default Electrical experts....Another question....
Might sound daft but....
What is the best way to supply mutilple (3x) ignition feeds from the ignition switch???
As far as i can remember, the ignition switch has 1 output switched wire (yellow IIRC), so what is the accepted way of expanding this?
A relay?
or is that overkill....
Old Feb 22, 2006 | 07:37 AM
St3V3_C's Avatar
St3V3_C
A relay would be the correct way, but what sort of current are we talking? If it's just for your neon washer jets then you should be OK.
Anything much bigger wants to be through a relay. And don't forget to fuse the main feed to the relay next to the battery
Old Feb 22, 2006 | 07:41 AM
CosRush's Avatar
CosRush
Well basically i have 3x switched circuits.
1x Fuel Pump Relay
1x Main components Relay
1x Direct feed to Ecu
Old Feb 22, 2006 | 09:40 AM
scruffythefirst's Avatar
scruffythefirst
do a 3 way connection, join one to each for the control pins for the two relays and the other direct to the ecu. The current for the relay control is minimal and the ecu only takes 5amps i think (its fuse rating is given in the manual)
Old Feb 22, 2006 | 03:07 PM
CosRush's Avatar
CosRush
Cheers for that
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
