Brake fluid question...
Im going to fit my AP's today & i was going to change the brake fluid to SRF but i cant get hold of any!
What alternative's are there to SRF?
& where can i get some from on a sunday?
Thanks people
Thanks people
is that like a silcone based fluid like the classic car people use so it dont damage your paint, or am i barking up the wrong tree.
Moondust_crust I think you might be thinking of something else.
ginge Not sure about it taking on alot of water tbh
Do i like regular brake fluid changes?... Hmmmm ... NO
But if it's gotta be done then so be it
Christian - what do you use then mate?
#1 in Spelling Club
Originally Posted by b19bal
dont srf take on ALOT of water,,,,,,, hence the use of stuff christian uses
do you enjoy regular fliud changes,,,,,,,,, serious question btw
#1 in Spelling Club
This is a very high performance Dot 4 brake fluid designed to perform at the extreme temperatures generated under race conditions.
It is a strong competitor for Castrol SRF.
It is noted that SRF is one of the best brake fluids available, but its major downfall is that it is very Hydroscopic, which means that it takes on moisture very easily. This results in the need for it to be totally changed every 3-4 months for optimum performance.
710 is far less hydroscopic, so can be changed less frequently. It also boasts a Dry Boiling Point figure in excess of 300°C, just like SRF.
Price is Ł10.99 per 1/2 Litre (around 1.5 - 2 litres is needed for a complete fluid change).
SMILER258
28-09-2015 09:04 AM
