brake disk cracked???
MISSING MY RST!!
one of my front brake disk on the RST has a crack right across it, the disks are standard from fords and only 1.5k old what do u guys think might have cause the crack cheers
MISSING MY RST!!
Originally Posted by b19bal
seized caliper
just finding my feet
depends tbh, a sticky caliper is what i ment,,, they bind but release at times so hiding the problem
happens on the rear of sierras/granadas more tbh
Re: brake disk cracked???
MISSING MY RST!!
set of black diamond (combi) disks and a set of green stuff pads
Just a thought, were you using EBC greens on your standard Ford Discs ?
IMO get a set of Mintex 1144's or Ferodo DS2000's pads for you new black diamond discs and you wont have a problem
MISSING MY RST!!
cheers for the advice i get on the phone tomoz and change my order
Originally Posted by wildheart
Ive carcked my grooved discs in months,might have somthing to do with the race pads and trackdays
Im sticking to motorfactor discs for how long they last!
Red dot
Had them on several cars over the years with 1144 pads and never had a problem,even had the same set on the S1 for over 7yrs and there still fine even after being on track.
The fiesta has them on now,done a 3 track days with the discs,first one using 1155's and they faded a bit and the pads cracked,swapped over to 1166's and they are fantastic on track,just not too kind on the discs
PMSL im not supprised then
BTW i found that using Mintex 1144's HARD on track causes them to crack right down the centre of the pad, is that what you found with your 1155's ?
The 1144's were perfect on the road and excellent for everyday use tho, but i have just changed over to Ferodo DS2500's for road and track use, will find out next weekend how they are round Bedford
Yep that where the 1155's cracked,not too bad but dont want to risk putting them in for bedford.
Just hope i dont have to emergency brake on the M1 going to bedford with the 1166's in
