TOPSPEED PROBLEM REVEALED !!!!!!
Old Feb 17, 2006 | 04:29 PM
Default TOPSPEED PROBLEM REVEALED !!!!!!
Block is cracked right across. NUFF SAID!!
Old Feb 17, 2006 | 04:35 PM
Rhys's Avatar
Rhys
OH no!!!! Nightmare Rod
What does this now mean?
peteh's Avatar
peteh
ouch
Old Feb 17, 2006 | 04:36 PM
CliffRS4's Avatar
CliffRS4
Gutted for you but I'm sure it will be back bigger and better very soon
Phil's Avatar
Phil
Jeebus
You found the limit of a 200block then!
Would liners even help with the torsional strength of the block?
Old Feb 17, 2006 | 04:37 PM
Mark V8's Avatar
Mark V8
Gutting
Are the Millington blocks stronger?
Mark
Old Feb 17, 2006 | 04:38 PM
RANJ's Avatar
RANJ
phil
rods block is a full on wrc nikasel linered item, you cant get better
RANJ's Avatar
RANJ
the millington items were not designed for turbocharging
Old Feb 17, 2006 | 04:39 PM
RANJ's Avatar
RANJ
shows how strong the crank/rods pistons are
Old Feb 17, 2006 | 04:40 PM
Phil's Avatar
Phil
Jeebus
Originally Posted by RANJ
phil
Where on earth could you go from there then!!?! Even increasing the capacity wouldn't reduce the force around the crank (from what I can tell) so that wouldn't be a solution!
I guess 2 litre pinto blocks just wern't desgined for a real 900+bhp!!
Old Feb 17, 2006 | 04:41 PM
ECU Monitor Enthusiast
That is a big shame Rod Certainly a new way of killing a cossie engine
Old Feb 17, 2006 | 04:46 PM
pee vee's Avatar
pee vee
bugger!
what next Rod and Mark?
are you gonna bother again? Real shame
Old Feb 17, 2006 | 04:50 PM
slipslide's Avatar
slipslide
noooooooooooooooooooooooooo
Old Feb 17, 2006 | 04:59 PM
It wont be soon & it wont be better, think we found the limit of a YB.
Not sure what to do, may just walk away & say 206 aint bad for an old Sierra. Mark will strip it down & check whats damaged. If its totalled, its game over as ive neither the time or inclination to start again.
Will chill before i make any decisions, car will make a good base for a future Topspeed car if i quit, anyone interested.
Rod
Old Feb 17, 2006 | 05:02 PM
GARETH T's Avatar
GARETH T
gutted for you rod,, but sadly this is the way we learn
Old Feb 17, 2006 | 05:05 PM
JonnyBravo's Avatar
JonnyBravo
Surely though if cars in Malta are running your sort of power for drag racing with what i would presume would be a 200 block then it could just be a case of bad luck, and not a case of finding the yb's limit.
Your car has been a huge influence in the world of Cosworth Tuning,
Surely you can't give up just yet, although imagining the money involved I couldn't blame you if you did.
Old Feb 17, 2006 | 05:06 PM
AlexF's Avatar
AlexF
gutted....
Alex
Old Feb 17, 2006 | 05:09 PM
Rick's Avatar
Rick
Old Feb 17, 2006 | 05:10 PM
andre_k's Avatar
andre_k
wounded!!!
how come martin hadland used one in his old engine? (iirc)
Old Feb 17, 2006 | 05:11 PM
RANJ's Avatar
RANJ
personal choice
Old Feb 17, 2006 | 05:14 PM
rapidcossie's Avatar
rapidcossie
bad news Rod...
hope you put the engine back together in one way or another...
RS scene wouldnt be the same with out old LFM
Old Feb 17, 2006 | 05:15 PM
Ryan's Avatar
Ryan
rod just a question
was the block long studded.
when i say long studded i dont mean your traditional longstudding.
i mean the ones that go all the way through to the main caps, like they use in sweeden and norway?
sad news indeed.
Sean Bicknell's Avatar
Sean Bicknell
Gutted for you Rod.
Sean..
Old Feb 17, 2006 | 05:21 PM
Kev.H's Avatar
Kev.H
Old Feb 17, 2006 | 05:22 PM
Old Feb 17, 2006 | 05:26 PM
ThomasRC's Avatar
ThomasRC
Bet you wish you hadnt installed that new NOS system!Bad news mate but enivitable as you just kept pushing and pushing,but atleast we now all know 900bhp is too much for a YB!!!!
Old Feb 17, 2006 | 05:28 PM
Mark Shead's Avatar
Mark Shead
There is another designe of Liners that we could use,I will be looking at the engine and seing what broke then look at a fix,
Also this was the original block we used in Rods old 500hp engine so it has already done 25k with 500hp and 5 of that was with 75hp nos, and 10k on this engine so we may also have found the life span of this block and mods.
Mark
Rossco's Avatar
Rossco
Gutting mate
Still it was running nearly 5 times the orignal power
Old Feb 17, 2006 | 05:31 PM
TIFF's Avatar
TIFF
Chasing Radders
Gutted for you Rod......
Old Feb 17, 2006 | 05:32 PM
JamesH's Avatar
JamesH
Gutted for you Rod ,
I hope the rest of the engine is ok
Good luck with whatever you choose to do
Old Feb 17, 2006 | 05:39 PM
luke89's Avatar
luke89
Team HOTHOT!
bad news rod hope that nothing else in the engine is fooked and that its just a case of trying to find a new block
Old Feb 17, 2006 | 05:51 PM
rssapphowner's Avatar
rssapphowner
stainless steel liners are the tits mate
not many people know about these
Old Feb 17, 2006 | 05:52 PM
James-W's Avatar
James-W
Originally Posted by andrek12345
wounded!!!
Lighter and has a taller block but those blocks are only rated to 400bhp so Martin was running over the limit anyway and Millington blocks aparently have a habit of cracking in na form.
Gutted for you Rod however it seems like its more bad luck than anything.
Hope you dont give up as the car has been a big influence to a lot of people and would be a true loss to the scene despite all the banter on here I properly respect your car.
Old Feb 17, 2006 | 05:54 PM
Originally Posted by Ryan
rod just a question
sad news indeed.
My block was the best available, as were pistons/crank. Lets see those Scandinanian drag cars do 13 ( yes it went on the 13th) 200mph Topspeed runs at Brunters. Big difference from a drag run to Held Flatout for 1.5miles we just found the limit. Marks special pistons. crank & rods outlasted a Mountune Nikasil linered block with lots of other tweaks.
Rod
Old Feb 17, 2006 | 05:57 PM
saffsta's Avatar
saffsta
OUCH sorry to hear that Rod
Old Feb 17, 2006 | 06:05 PM
jr's Avatar
jr
Gutting
really hope the car comes back in some form
Old Feb 17, 2006 | 06:09 PM
Mark V8's Avatar
Mark V8
Are blocks only made from cast iron for cheapness and for easy machining? surley they could cast in steel and it would be a lot stonger. Paying for a one off casting would give the wallet a good hammering though
Mark
Old Feb 17, 2006 | 06:11 PM
L9KOS's Avatar
L9KOS
a true shame , sorry to hear it mate.
would be a total loss to the scene if this is it tho!!
Old Feb 17, 2006 | 06:12 PM
3drstretch's Avatar
3drstretch
Was it defo the last run that caused the damage though or just as mark suggest the lifespan of such an engine.Ie 25k miles.So if built to same spec again could it not be used for another say 20k as it more potent now.
Old Feb 17, 2006 | 06:15 PM
Can i say im a bit upset at the mo, as most people who Know me realise i was planing to quit end of March after Vmax & a mag feature. These will now not happen & im proper gutted. Totb was never an option & despite pressure from totb to run it was past my cutoff date.
Will wait to see the probs & time/cost of a fix & make a decision, remember im not a company so no monetory gains to carry on, im also a lot older than you guys, would your Dad carry on .
Rod
