Boost to A/F ratio
Boost to A/F ratio
I've seen it said that for a certain amount of bosst you need to a certain A/F ratio. For example 20psi = 12.1 a/f, 30psi = 11.1 a/f
Can anyone give some good info on this or is it engine set up dependant only? Thanks, David
It is usually a case of what your engine is happy to run without detonation and with reeasonable EGTs. Expect on boost AFRs to be between 12.5:1 and 11:1 in most boosted applications.
That what I thought. But was having a conversation the other day with some local gearheads and one of them said that with running 32psi that they should be running around 11:1 afr. I asked how he could just come up with that figure. He couldn't really give me an anwser. So I figured I'd ask if there was a formula or something.
Its about that figure for most engines... it does vary but not by much!
Peak power is around 12.5:1 but you normal run a bit richer than that to be on the safe side.
Alex
Alex
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
