Rotors and bells - how do you measure.........
Team HOTHOT!
When looking at rotrs and bells, and you need replacement rotors, how do you measure the PCD of the rotor?
some are 180mm, then some are 203mm and some are even 220mm
is the PCD the physical size (diameter) of the bell, or the distance between 2 opposing boltholes on the bell where the rotor attatches to?
Team HOTHOT!
Rite, i've just measured
the distance between the holes opposing each other for the mounting bolts is 205mm and the overall diameter of the bell is 220mm
now i'm confused
now i'm confused
PCD = Pitch Circle Diameter, the diameter of the circle of the studs.
I assume you're talking about where the bell attatches to the rotor, not the PCD of the wheel studs.
Resident Wrestling Legend
you measure between the centre of one hole and the centre of the opposite hole on the actual disc inner bit where they bolt on
there are different discs on the market so you would possibly best off trying to get replacements from one of the big names
as far as i know they are all of a certain standard but you do get these wierd ones from time to time
OrionRST200bhp
29-09-2015 08:30 PM
james kiely
28-08-2015 08:58 PM
