Show me your Cossie Air filters
#41
Originally Posted by dumped
To convert to T4 spec takes about 2 mins, - mike could you not do this yourself? Office hands - sorry forgot lol
Cars coming on pretty well - the run in is upon us dammed if i want to drive the clutch though - dont think i am trusted for the first few miles on the car lol
i looked my old one out last nite and would have to some serious shimming up to get the t4 hose to fit.
dont want to restrict the air coming into the car by fitting a smaller box onto the car.
Is the "run" going to be on the road marty??
will alan be driving??
#45
I rang up & sought Technical advice from K&N & was told this was the best they had & gave figures to prove what it would flow. Boxed it in & no ones going to say it dont work . Its fed cold air from underneath & also ducted from the front, its a tight fit & a right pig to re-fit when its taken off.
#46
what did you use to box it off? is it just a sheet of aluminium or something??
#49
looks cool Rod!
Rod
#51
Re: T4 lid
Originally Posted by 3dr wixsy
I think ive got one somewhere, i used it as a template for an alloy one i had made, ill have a look tomorrow if you want mate
#52
looks cool Rod!
Rod
#53
Caraholic
As Martin says, the Escort airbox lid is a two piece design, with the 65mm "trumpet" being a push fit into the end of the air box. Obviously this "should" make it relatively easy to do a spun aluminium replacement item to any size to enable anyone to swap over.
That's the theory, the reality is, YOU try removing it from the lid . It is well glued in or twists out, and haven't yet figured out the best way to separate the two, so if anyone knows how this is done without damaging the lid, I would be eternally grateful .
#54
.............haven't yet figured out the best way to separate the two, so if anyone knows how this is done
I did this about 3 years ago (on the old T4 spec)............BTW - the internal hole diameter is 86 mm
......some lead the way....others follow
#57
Doug,
You haven't pictured the spun aluminium trumpet you obviously inserted to achieve the correct 76mm connection to the T4?
So is it just glued in then, as I don't want to break the lid ?
#58
Caraholic
Originally Posted by Doug Stirling
Doug,
#59
That info is greatly appreciated. Accordingly, I will not post any piss-takes against you for 28 days .
That seams a little Mickey Mouse to me, so would prefer to attach a trumpet
#62
Originally Posted by doug stirling
Originally Posted by mike rainbird
that info is greatly appreciated. Accordingly, i will not post any piss-takes against you for 28 days .
that seams a little mickey mouse to me, so would prefer to attach a trumpet
Absolute
#64
Caraholic
ABSOLUTE
#65
Dave, you can fuck right off though, because if you hadn't noticed (blinded by all that wanking ), it is still on the T34 / silver painted cam cover in that picture and this is the way I bought it .
Ok, here is a current picture of your engine..NOT how you bought it
with EXTRA crappy glorified 'aeroquip' jubilee clips
ROFLOLOLOL
#74
Testing the future
back on topic mike, maybe the escos lid can be put into a warm oven to melt the glue?
i would have thought that the glue might go soft before the thermoplastic melts, but you try convincing the missus that you won't get a pile of melted plastic in the bottom of the aga
#76
I'd love to see some more pics of this Rod, if you're willing to share.
I'm still pretty dubious about all the hot air my pod filter sucks in, but I had to remove the old airbox as when I fitted my Pace RS500 Spec Intercooler I had to remove the air splitter and the piping that ran to the air box
Here's my current setup on my 2WD Sapphire (admittedly it's only a T3 )
#77
Super Moderator
ROFLOLOLOL
#78
stil waiting on rod posting pics up after saying he would do it
i have bought a sheet of thin aluminium heat sheild stuff from demon tweeks and am going to make something similar to rods set up.
will post pics by the end of the week.
Karl 3dr
102
14-10-2016 08:17 PM
track.focus'd
12-08-2015 05:53 PM
Escortdriver1
05-08-2015 12:45 PM
