Differnce between T34 and T35?
Old Feb 12, 2006 | 10:33 PM
buftyboy's Avatar
buftyboy
Default Differnce between T34 and T35?
as above,whats the difference???
Old Feb 12, 2006 | 10:35 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
t35 are commercial,thousands of variations and most unsuitable for car applications,many ppl mistakenly call t34 a t35
Old Feb 12, 2006 | 10:37 PM
twitchyrear's Avatar
twitchyrear
ive got a t35 from steve scott at a1 on my car(says t35 on recipt)
Old Feb 12, 2006 | 10:40 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Turbo Technics even call theirs a T35, what chance have we got
it's a T34 end of
Old Feb 12, 2006 | 10:44 PM
dannyblackpool
Boost Builder
t35 sounds bigger than t34
Old Feb 12, 2006 | 10:45 PM
JonnyBravo's Avatar
JonnyBravo
I was told that a t34 was when a .48 ex housing is used then a t35 is when the .63 housing is used.
Clearly that was utter bollocks
Whats a t38 then ?
twitchyrear
is it something to do with ex housing then??
Old Feb 12, 2006 | 10:48 PM
dannyblackpool
Boost Builder
escorts were .63 from factory and were called t34!! TB3403 to be exact!
T38 is t34 comp cover machined to take larger wheel although at moment isnt a set size wheel with different companys using various wheels
Old Feb 12, 2006 | 10:50 PM
twitchyrear
im none the wiser how do i check the housing size??
Old Feb 12, 2006 | 10:51 PM
JonnyBravo's Avatar
JonnyBravo
I see your point about the esc cos turbo !
So T38 is t34 compressor housing ? but machined to take slightly larger wheel ?
Old Feb 12, 2006 | 10:52 PM
dannyblackpool
Boost Builder
ex housing will have a/r .63 or .48 on as part of the casting
Old Feb 12, 2006 | 10:54 PM
twitchyrear
cheers,might change the sig to read T34 then
Old Feb 12, 2006 | 11:04 PM
buftyboy's Avatar
buftyboy
cheers all
Old Feb 13, 2006 | 09:02 AM
stonehavencossie's Avatar
stonehavencossie
Whats a t38 then ?
I have a T35 .55
Old Feb 13, 2006 | 03:04 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Whats a t38 then ?
I have a T35 .55
How do you find the t35 with the .55 mate, i have a t34 with a .48 but have a chance of getting the same as yours, what boost do you run and how much power do you have?
Old Feb 13, 2006 | 03:08 PM
CharlieSaff's Avatar
CharlieSaff
I have a T34 0.63
Old Feb 13, 2006 | 03:13 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
https://passionford.com/forum/viewto...459&highlight=
Old Feb 13, 2006 | 05:02 PM
stonehavencossie
Whats a t38 then ?
I have a T35 .55
Just running a safe 22 psi on stage 3
Stu from msd commented that it was a good turbo when he fitted it.
I like it. You get the best of both worlds (not to much lag and holds pretty well)
Old Feb 13, 2006 | 05:03 PM
stonehavencossie
p.s. where u from?
Old Feb 13, 2006 | 05:24 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
A T35 is a van/truck turbo and far from suitable on a car.
The correct turbo is a T34, NOT a T35.
Old Feb 13, 2006 | 05:49 PM
Billabong's Avatar
Billabong
People call them T35 as it sizes it nicely between T3 and T4, but Ford (T3/T04B)/Garrett (as per Danny) didn't call it this, and as said, there is already a turbo designated a 'T35'. It is often called a 'T34' as that is close to the Ford T3/T04B designation.
Old Feb 13, 2006 | 07:13 PM
LEE-RS's Avatar
LEE-RS
Custom
Old Feb 13, 2006 | 07:31 PM
NUTTIN RILLA
p.s. where u from?
Ayshire mate
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
