mobil 1 oil???
mobil 1 oil???
just bought my first cossie witch has been run on mobil one is it ok? have heard stories before that it is to thin for older engines is this true or just a fairy tell?????
2Evos & 1 Escort Van :-)
Two types of Mobil One to look out for matey - I use as do many on here Mobil 1 Motorsport 15/50 Ideal for Cossies
Don't use normal 0/40 - that is like piss.
PM Matt at ML for best prices - normally Ł20 for 4 litres, or try Halfrauds and pay Ł37 for the same stuff
just finding my feet
0-40 is actually not THAT bad as you all make out
i ran it on my cossie as a mate had a 205 litre drum of the stuff and it was fine,,,,,,,, when it got rattly a few tuners mentioned about it being the oil making it do that and to change to 15-50 and see the difference and so as i had a 7 litre sump i bought 75 quids worth to find,,,,,,,,,,,, wait for it
FOOK ALL DIFFERENCE !!!!!!
its a nicer oil and will shut up the tappets i supose but i remember that 10-40 caused the zetecs to have sticky valves and ford actually recomend -30 oil on cossies ect now
Originally Posted by Lambchop
i wanna get me some of that! i take it you can post oil?
does matt post here much? i need oil for when i get onshore!
chop
He can post oil, but generally I see him at shows and pick up a few cans every few months.
His name is Matt Lewis - not sure what he posts under on here - either that name or Matt@ML rings a bell.
If you're stuck I'll try and find out his proper user name if I can
Simon
Originally Posted by b19bal
Originally Posted by grey RS
i've always used the motorsport 15w50 with it
how can you have,,,,,, it aint been about over 3 years has it
http://www.mobil.com/UK-English/Lube..._Super_XHP.asp
point proven
dont use 0-40 in a yb
