quick question, answer needed asap
Old Feb 11, 2006 | 07:00 PM
16vzetec's Avatar
16vzetec
Default quick question, answer needed asap
i should be able to fire up my 2.0l zetec mk4 tomorrow but before i did i thought about doing a compression check as im worried about too high compression.
its a n/a 2.0l that is 0.5mm oversized.
i am running a ported 1.8 head.
apparently this will raise the compression ratio but i also have a metal tripple plate head gasket of which i have noticed is thinner than the standard item.
so my question is;
what psi is safe for my engine?
basically what will happen if i got too much compression??
cheers peeps
Old Feb 11, 2006 | 10:54 PM
NUTS RuS's Avatar
NUTS RuS
140 - 180 ish at a guess will be fine.
A.t.p
Aug 15, 2015 11:37 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Ben26
Aug 11, 2015 04:19 PM
liam-rst
Aug 10, 2015 08:46 AM
col93saphcos
Aug 7, 2015 03:21 PM
