Computer Help.........
Old Feb 10, 2006 | 08:45 AM
FAST AS FORD's Avatar
FAST AS FORD
Default Computer Help.........
Im trying to copy data onto a cd-r but it keeps getting an error and fooooking the disc up so i have to bin it!!
It can happen at any time! and usually takes until i get to the 3rd or 4th disc before its copied!
I dont have any probs copying music, it seems to work fine every time, its just with data, i.e folders and files.
Is there anything im doing wrong? Do i need to change the settings or something?
Pleeeeassseeeeee help as im buying packs of 10 and bunging away 6 or 7 of them
First one to help will receive a shiny drinks coaster
Old Feb 10, 2006 | 09:02 AM
fiestasimon's Avatar
fiestasimon
try burning at a lower speed? might help
make sure you files are the direct path to them instead of shortcuts.
Old Feb 10, 2006 | 09:19 AM
FAST AS FORD
How do i adjust the speed? and how do i know if the files are a direct path?
Sorry for being dumb
Old Feb 10, 2006 | 09:35 AM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Try burning at a lower speed, try buying better discs, try buying a better burner..... process of elimination
Old Feb 10, 2006 | 09:36 AM
FAST AS FORD
How do you lower speed
Old Feb 10, 2006 | 10:04 AM
saff_cossie's Avatar
saff_cossie
To lower the speed look for the drop down list on the same page as you click "burn"
Will read something like 32X, 16X, 10X, 4X
Drop to 10 or 4 to be safe. Has certainly helped me before.
Old Feb 10, 2006 | 10:07 AM
FAST AS FORD
Hmmm, I dont click on "burn" i just drag files over to e-drive and then it copies. How else do i get to it?
Old Feb 10, 2006 | 10:09 AM
fiestasimon
are you using the windows cd burning tool,
if so thats crap, go and get a copy of nero or easy cd creator.
should solve your problems
Old Feb 10, 2006 | 10:12 AM
FAST AS FORD
Yeah, i guess so, where do i get them from?
Old Feb 10, 2006 | 10:20 AM
FAST AS FORD
Aha, Finally found the speed setting! It was set to fastest I've taken it down to 8x, is this a good speed? Im copying about 650mb of data to disc, is it gunna take days?
I usually do it in chunks of 50mb or so rather than drag all 650mb across, is this worth it or does it make no difference?
Thanks for your input, Much Appreciated!
Old Feb 10, 2006 | 11:16 AM
monkey24's Avatar
monkey24
if that doesnt work i would suggest your burner is fooked.......download nero trial version from the nero website. you can always find nero cracks..... where in north wales r u?......im a puter engineer btw
Old Feb 10, 2006 | 11:43 AM
FAST AS FORD
I used to live in rhos on sea (near llandudno), but im living up in Lancaster at the mo. Don't think much of it 2 b honest but its only till sept, then who knows
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
