Cometic Head Gaskets--Who has had problems with them
Old 22-07-2004, 06:49 PM
  #41
sunny
sunny's Avatar
Very sad to hear this mate.
How long was you running the gasket for and what other damage has resulted from the gasket fault?
Bests - Sunny.
Old 22-07-2004, 06:51 PM
  #42
Benn 304R
Benn 304R's Avatar
never had any problems with mine
Old 22-07-2004, 06:53 PM
  #43
TIFF
Chasing Radders
TIFF's Avatar
Bests - Sunny.
Sunny
The car wasnt even fired up
Water was coming from the side of the gasket as it was made with an imperfection in it. Therefore damaging the head and block.
Old 22-07-2004, 06:56 PM
  #44
sunny
sunny's Avatar
Tiff - might sound a bit daft but I am confused as to how it can damage the head and block if it wasn't fired up mate?
Either way mate.....I hope you get it sorted.
  #45
Deano
Deano's Avatar
OUCH
Old 22-07-2004, 06:57 PM
  #46
DaveEscos
DaveEscos's Avatar
how can it damage the block and head if the car hasnt even run!
Old 22-07-2004, 06:58 PM
  #47
TIFF
Chasing Radders
TIFF's Avatar
Sunny
When the head was torqued down onto the gasket and the block, the imperfection caused it to damaged the 2 surfaces
Old 22-07-2004, 06:59 PM
  #48
cossie1
cossie1's Avatar
I'm guessing that a part of it was not level therefore when it was tightened down it put pressure on the head and block, therefore leaving indents on the head and block ?
Tiff am I right ?
  #49
TIFF
Chasing Radders
TIFF's Avatar
It is being sorted
  #50
Deano
Deano's Avatar
Sunny
Can you not skim the head and get the block decked
Old 22-07-2004, 07:01 PM
  #51
TIFF
Chasing Radders
TIFF's Avatar
Sunny
Deano
It is all in hand mate
But my argument is, who is paying for the un-nessesery damage that was caused by the faulty gasket?
Old 22-07-2004, 07:03 PM
  #52
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
was it the firing rings which are separate had not located properly in the layered bit and fooked it??
i was looking at mine and it looks quite possible
cheers
Daniel
  #53
Deano
Deano's Avatar
Ahhhhhh point taken
Old 22-07-2004, 07:26 PM
  #54
markk
markk's Avatar
TIFF-C20WTH,
you are !
Old 22-07-2004, 07:27 PM
  #55
Deano
Deano's Avatar
Originally Posted by markk
TIFF-C20WTH,
you are !
But he shouldnt be
  #56
TIFF
Chasing Radders
TIFF's Avatar
At the moment i am....................but i wont be
  #57
markk
markk's Avatar
if you dont , then your car will be off the road for the next millenium whilst the courts sort it , the , if you do pay for it to be repaired they fook you off for the payment cause youve allready had it repaired - either way - your fooked - but good luck
Old 22-07-2004, 07:28 PM
  #58
TIFF
Chasing Radders
TIFF's Avatar
markk
I know exactly what you mean mate
Old 22-07-2004, 07:29 PM
  #59
markk
markk's Avatar
a sorry state sometimes - sometimes u just gotta bite the bullet
Old 22-07-2004, 07:30 PM
  #60
markk
markk's Avatar
i too would be mad as fook , but what do ya do in a catch 22 situation , #(now dont take this personally !) but your a loser !!
as we all would be in the given situation
Old 22-07-2004, 07:31 PM
  #61
Rene
Rene's Avatar
glad karl is getting it al sorted for you
top man he is
Old 22-07-2004, 09:36 PM
  #62
TIFF
Chasing Radders
TIFF's Avatar
All sorted now
New head gasket on and all is fine.................................just the fucking injector problem now
BIG BIG BIG thanks to Karl for everythink he has done today, Those who know what has happened will understand
Karl, Thanks Bud
Old 22-07-2004, 09:45 PM
  #63
Rs Gus
impreza wrx sti version 8
Rs Gus's Avatar
i have a .57 cometic and its fine must be the shonky 3dr it was fitted to!
Old 22-07-2004, 09:49 PM
  #64
Sticky.
Sticky.'s Avatar
Sorry to here about your nightmare with the head gasket Mark
Im glad it's all sorted now
We getting a few pic's then Tiff
Old 22-07-2004, 09:51 PM
  #65
marco polo
marco polo's Avatar
Gus
i would have a shonkey 3dr over a shonkey saff anyday
Old 22-07-2004, 09:52 PM
  #66
TIFF
Chasing Radders
TIFF's Avatar
Paul
It doesnt rain mate, it pours
Problem with the injectors or loom now
  #67
Rs Gus
Rs Gus's Avatar
private joke mullet boy
Old 22-07-2004, 10:26 PM
  #68
Ima-Racing500
Ima-Racing500's Avatar
Tiff...unfortunately the injectors from Bosch are NOT meant for the application used!!!!!.....If for example a Dark green failed that would be as far as Bosch are concerned on a Porsche 944 Turbo...now that would NOT damage a std motor....These are modified cars and NO garantee applies except for the part itself.
Sorry,welcome to the world of tuning If you have issues keep the car standard...sorry.
Old 22-07-2004, 10:37 PM
  #69
Rene
Rene's Avatar
don't mess with me dad now
glad its all sorted reg. the HG top man karl
Old 23-07-2004, 01:44 AM
  #70
RWD_cossie_wil
RWD_cossie_wil's Avatar
all well and good, as you correctly state injectors etc are generally a universal part, used on many different applications, hence cannot be held responsible for faults/damage, BUT a COMETIC head gasket is designed SPECIFICALLY for use on a cosworth engine, and should therefore carry a suitable warranty, as it is a FAULT with the MATERIAL used to manufacture the gasket, hence causing the damage so cometic have a responsibility for the damage as THEIR faulty product caused damage on correct application of a faulty gasket
Old 23-07-2004, 09:29 PM
  #71
Karl
Norris Motorsport
Karl's Avatar
Just to give a quick run down on the problems found so that anyone using a cometic gasket in future can double check this!
After I had rebuilt the engine using a cometic gasket the first thing I did was refill the coolant system. After I had filled it I noticed water leaking down the block. Upon inspection its was coming from the side of the head gasket.
Thus I stripped the engine again and indentations were found in the head face and block. Upon examining the gasket it was found that the seperate fire rings that sit in the middle of the 3 layers were slightly larger in diameter than the cut out in the middle layer!!!! This was causing the fire ring to sit slightly proud and thus hold the head up enough to leak. However it damaged the head and block in the process.
It's not an easy fault to spot and I didnt before fitting it even though I visually checked the gasket over. The three layers are quite loose and thus I doubt I would spot the fault again until the head is torqued down!! Unless you actually pull the outer layers apart to view the centre layer and fire rings its almost impossible to detect! (And its not a good thing to start pulling the steel layers apart with a new gasket!!)
Thus everyone BEWARE!!!!
As a summary I pulled the engine out machined both the block and head faces and rebuilt with a genuine Mountune gasket! Its now 100% perfect again no thanks to Cometic!!
Hope this small bit of info may save someone elses engine, allthough it does seem to be a rare fault!!
Old 23-07-2004, 09:40 PM
  #72
Ian3dr
Ian3dr's Avatar
Sorry to hear of your probs Tiff but a big to Karl!
Old 23-07-2004, 10:26 PM
  #73
Ima-Racing500
Wil...no modified parts are warrantied..except the part itself.....UNLESS its a std engine!
I bought a cam belt kit for my Transit from FORD and they warrantied it for 60000 miles!!!So if it snaps they will fix the engine ...To avoid any complications re fitting..i got them to do it!!!Cause thats the only way a warranty will work..LOL.
Karl..i'd say you made a mistake!!!!!I know i was paranoid i would get the line up wrong on the Cometic..and i could see you could easily not line it up perfect!!!!!!But hey blame the gasket..LOL...NO DISRESPECT..but even genius's can fook up.
Old 23-07-2004, 10:42 PM
  #74
Karl
Norris Motorsport
Karl's Avatar
LOL Phil, the gasket was at fault. If I had made a mistake I would simply have repaired it and not bothered warning people of this fault.
Old 24-07-2004, 09:22 AM
  #75
Damo V
Damo V's Avatar
Thas bad news Karl/Tiff..... sorry
Old 24-07-2004, 10:57 AM
  #76
Escort_Cos
Escort_Cos's Avatar
i have had the thicker cometic in for two years now running 32 peak pounds of boost and it has been fine
i think you must have had a rogue gasket tiff
Old 24-07-2004, 11:21 AM
  #77
JAP CRAP
JAP CRAP's Avatar
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
I know of someone who had race logic traction controll on his RX-7. apprantly the system in some way caused the engine to blow.....due to stoping fuel or something (I dont kznow the details) . Anyway, AFAIKR racelogic footed the bill for the rebuild....
Old 24-07-2004, 03:39 PM
  #78
PJ MOTORSPORT
PJ MOTORSPORT's Avatar
Cometic gasket came from us,regardless of what Cometic say we will discount your next purchase or reimburse you either way!Give me a ring on Monday to sort out.Buy Karl a beer as he was at our door sharpish after the phone call!-regards PJ.
Old 24-07-2004, 04:04 PM
  #79
Matt
Matt's Avatar
good man pj top offer
Old 24-07-2004, 09:31 PM
  #80
TIFF
Chasing Radders
TIFF's Avatar
PJ
Cheers mate, i will ring you Monday
Top Man
Quick Reply: Cometic Head Gaskets--Who has had problems with them
