bias pedal boxes
Vehicle brakes need to be re plumbed so they are front / front and rear / rear, and not cross diagonal like they are now.
You can then set the 'bias' between front and rear brakes to get a far better brake balance, and firm pedal feel.
Not strictly a 'bolt on job' then due to the above work required.
WELL worth fitting in my opinion but you are looking at well over £1k to get a proper one in there I think. Don't know what I paid but it was more than that.
Looks better now its powder coated
Not strictly a 'bolt on job' then due to the above work required.[/quote]
You can say that again Took me forever to sort the Wilwood one to my escos
it fits slightly differently to Porkies ie the cylinders are indide the car, under the dash
Had to lower the steering column to get it all in
Thats what I thought... but its bollox IMHO. And you don't 'stomp' because you have alot more feel. You squeeze....
Sona, Rentons wife must be all of 5 stone and she drove Martins Escort without even realising it had no servo.
Lovely engineering on the pedal box Lee.....who made it?
Never had any trouble with the pedal on a car fitted with a bias box....correctly selected master cylinders is the key.....
Martin had it made. I think it was EARS???? not sure, Sorry
does this sound right?
btw its my capri
cheers
btw its my capri
cheers
XR - you're overly complicating it.
One master cylinder is for the rear brakes (usually through a hydraluic handbrake) - one line from the cylinder to the rear of the car, then t-pieced to each caliper.
The fronts usually have one feed to each front caliper from the cylinder.
You then use the balance bar to........... er balance between the feed for front and rear.
You can get pedal boxes in 2 and 3 resevoir formats, but the hydraulic clutch is a worthy mod.
got ya mate
always wondered how they plumbed up lol
well im not going hydraulic handbrake as i need the car to be road legal aswell
you say balance bar is this the bar in the pics above where the rods for the cylinders are on or is there another one in there somewhere
is it possible to use a brake bias valve so it can be done manually while driving insead of adjusting the bar or is it just worh setting the bar and leaving it as it is
but thanks fo rthe info much appriciated
Originally Posted by broadmoor
but with respect you would'nt need to adust it whilst driving? unless your considering a entering a WRC event?
Originally Posted by xr4x4rs
got ya thanks porkie
how much was the box if you dont mind me asking
do you know if it comes with everything complete and is it a job that people can do or is it a job for the pros
Sorry mate, I don't ever get bills or receipts from Martoon to be honest. So I have no clue!
BUT unless you are very serious about your trackdays or just love spending money on old Fords I wouldn't bother mate. Stick with whats there and fit a bias valve like a used to have.
sobster or porkie
how do you adjust the rod lenghts on the master cylinder.when the pedal is fully depressed or without any pressure on the pedal.have been told both so wich is the correct way?
Heres my pedal box and my blue adjuster knob all installed by Danny B
I only have an inch pedal movement and i love the feel i now get when braking
well im new to all this and would like to start doing track days as much as i can when the cars built
i would keep what i have but i would need to wire the abs into a mk4 and wouldnt know where to start at that point hence asking about pedal boxes
plus ive heard its bad to use the abs system on track with aps front and rear how true this is i dont know
but i also need it drivable on the raod as i would have some fun at weekends lol
if anyone knows how to wire up the abs then ill leave it in lol
sobster or porkie
its the pivot position between the two that changes to provide bias across the two cylinders and hence more/less pressure to one or the other.....
altering the master cylinder rod length would adjust pedal travel and braking would occur early either on the front or rear first (dependant on which master cylinder rod you adjusted) if that makes sense......lol
see if i get this straight.
the lenght of the rods should be equal when the pedal have no pressure on it?
if so i have it all wrong on my setup
ohh and it should be sibster not sobster
sorry for that one
cheers
sorry for that one
cheers
sorry for that one
cheers
sorry for that one
cheers
You are correct IMO if you have lets say the rod length longer on the front cylinder you will be braking earlier (less travel before the cylinder engages) on the front with little effort towards the rear, this may promote the characteristics you want but it isn't using the bias pedal box principle as it should be used.....
Regards
Ian
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
