another mapping question
Old Feb 5, 2006 | 12:02 PM
Jay,'s Avatar
Jay,
Sponsor
Default another mapping question
ok right i got bd10s in my coz when it was on a l6 it sounded even on idle but the co meter varied up and down slightly as did a electronic rev counter and i got more or less the same prob now on the dta ecu is it the the cams could do with adjustable pulleys or just more refinement on the map
cheers jay
Old Feb 5, 2006 | 12:11 PM
Stu @ M Developments's Avatar
PassionFords Creator
Potential airleak issue, get the thing pressure tested before looking too deeply at the mapping.
Then try another AFR setting as engines running lean generate lots of torque and teh idle raises if they get a hint of extra fuel.
Finally.. ensure the base idle setting is correct so that the ISCV is doing NOTHING AT ALL.
Old Feb 5, 2006 | 01:36 PM
Jay,'s Avatar
Jay,
Sponsor
cheers stu checked for leaks nothing there tried different afrs at idle not much diff but the idle could be at fault then as the valve will click when car is cold so mabey i little work on the pwm map maybe needed
cheers jay
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
jay030787
Sep 25, 2015 01:38 AM
