Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
diy blasting
Old Jan 16, 2012 | 08:04 AM
boaby's Avatar
boaby
Miester
Default diy blasting
anyone diy blasted their car? if so what did use use?
i seen a few items
http://www.ebay.co.uk/itm/Shot-Sand-...c#ht_634wt_800
http://www.ebay.co.uk/itm/Sand-Blast...1#ht_916wt_800
http://www.ebay.co.uk/itm/Sealey-SB9...ht_1803wt_1034
any of those look decent?
Old Jan 16, 2012 | 09:23 AM
Turbosimpsons's Avatar
Turbosimpsons
i bought one of the 20kg drum types simular to the sealy-sb9...ht one. it is worth its weight in gold for blasting medium sized parts, you could blast a car with one, but it would take you about 3-4 days and about 2ton of dried sand. you would also need a large compressor. mine only just does it and it's a 3hp 12 cfm 150ltr comp. also the mess it makes. make sure the sand or grit you use is bone dry, any dampness blocks the blaster.
Old Jan 16, 2012 | 11:47 AM
boaby's Avatar
boaby
Miester
excellant, cant remember what size my compressor is, do you reckon i would remove underseal and stuff?
Old Jan 16, 2012 | 01:37 PM
JonnyBravo's Avatar
JonnyBravo
SandbLasters won't remove underseal or anything like that, the media just bounces off it
Old Jan 16, 2012 | 02:13 PM
boaby's Avatar
boaby
Miester
so ok for the top and side of a car but not underneath?
Old Jan 16, 2012 | 02:35 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i once blasted a hole lambretta with a small hand held one from the snap on man! it worked really well
Old Jan 16, 2012 | 09:07 PM
SMILER258's Avatar
SMILER258
it would be ok underneath on bits not covered in underseal, i did mine. And wear a mask! i didnt and it hurt to breathe for a day, stupid mistake that was. if removing underseal, wire wheel on a grinder.
Old Jan 26, 2012 | 08:45 PM
dingla rs's Avatar
dingla rs
you have 3 options there
1 = waste of time there crap
2= waste of time
3 = ok ish if you have a big compressor , we have one but never use it
option 4 grinder and a good wire wheel is ur best bet
3doorcozmess
Sep 20, 2015 06:15 PM
jonfoc
Sep 11, 2015 04:46 PM
rog
Sep 4, 2015 07:24 AM
