Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
mk3 escort quick shift?
Old Feb 7, 2014 | 07:44 PM
pikachu's Avatar
pikachu
Default mk3 escort quick shift?
Hey guys.
My gear changes have become very sloppy from a loose gear linkage.
Does anyone supply quickshift kits for the 5 speed XR3i?
cheers.
Old Feb 7, 2014 | 07:49 PM
escortmk3rwd's Avatar
escortmk3rwd
puma goes on just got to drill 2 holes
Old Feb 8, 2014 | 09:02 PM
pikachu's Avatar
pikachu
Really? I've been told its a pretty easy thing to do.
What involved then? Is it literally a case of drilling two holes for the bolts into a short shift puma kit or is it the standard kit I use?
Old Feb 8, 2014 | 10:51 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
It's as easy as is already mentioned . Not a short shift as such but a very good cheap upgrade , I have one on my S1 . Much nicer feel to the gear changes and well worth the effort of drilling 2 holes
Old Feb 8, 2014 | 11:03 PM
pikachu's Avatar
pikachu
Cool! Got any pictures for me to use as a reference?
Old Feb 8, 2014 | 11:43 PM
Chopshop85's Avatar
Chopshop85
This is a picture of the bolt holes. You can see the two holes I drilled just behind the standard plate, which I ended up using to hold a steel plate to prevent there being a hole under the center console.
I found that the linkages bolted together are slightly different lengths. So the stick sat closer to the dash.
I ended up lenghtening the rods by 18mm
Bear in mind that if you are running a standard BC gearbox the puma gear stick will not self center when knocked out of gear.
Old Feb 9, 2014 | 09:53 AM
pikachu's Avatar
pikachu
Seems a bit too much work for me to be honest! but cheers for showing me I may as well just get a standard unit nothing wrong with them after all.
Old Feb 9, 2014 | 02:20 PM
Roscopeco's Avatar
Roscopeco
Ignore the above if you get one from a puma you dont need to do any of that except drill 2 holes . The rest just bolts up !
Old Feb 9, 2014 | 02:29 PM
Chopshop85's Avatar
Chopshop85
That is a Puma linkage.
Yes you can just bolt it up. I just wanted it to sit correctly and didnt fancy having a hole in the floor of the car as my old linkage had been chucked before I could take it to bits.
andyrs1600i
Apr 29, 2026 03:21 PM
FlashRS
Sep 14, 2015 12:36 PM
s1turboman
Aug 29, 2015 04:27 PM
Vincereese
Aug 18, 2015 03:57 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
