XR2 Mk2 Roof
Hello,
So to get straight to the point. I have a rust bubble on the roof and the whole roof is getting sprayed in the next week or two. The whole car had a respay a few years back but apparantly this bubble appeared a few month after. Is there anything anyone would suggest to slow this down now its being sprayed again? Or if the whole roof is fucked, what route to take?
Stuart
Stuart
There was a bubble infront of the sunroof. im getting the whole roof sprayed this week anyway for now. I was just worried about the rest of it because i cant see! Some of the paint bubbling by the gutter on the drivers side to. if its that bad i will just cut it all out and re-do with out the sunroof. has anyone already done this?
As long as there are only "rust bubbles" there usually is no need of replacing the whole roof!? Get rid of the paint to check how big the problem really is. When it's just surface rust it can be cured easily and won't come back (grinding, sanding, tinning, filling, painting). When it goes deeper you can just replace small pieces of the roof by cutting them out and welding new metal sheets in. And when the old paint gets sanded down, additional rust problems will be revealed.
Kiran1600E
11
Oct 2, 2015 11:35 AM
i was affraid that was the only choice! What about a carbon roof replacement? are these road legal?
