Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
xr3i
Old Jan 14, 2013 | 07:00 PM
chrisgcombi's Avatar
chrisgcombi
Default xr3i
Hi just wondered if any one may know why my efi xr3i doesn"t have much poke , its running ok but doesn"t seem to be goin as it should . Any help would be appreciated
Old Jan 14, 2013 | 07:01 PM
the_frozen_one's Avatar
the_frozen_one
Depends how many miles and service history? Tired engine with worn cams and low compression are usually pretty slow
Old Jan 14, 2013 | 07:16 PM
Fordmad!'s Avatar
Fordmad!
As above youngest engines are 20 years now and probably had a hard life!!!
Old Jan 14, 2013 | 07:19 PM
chrisgcombi
Engines been well looked after , had a tuning specialist as it was runnin rich and he said it looks like some one has spent a lot of money on it .
Could it be anything to do with ecu or boost valve or injectors etc as i am stumped .
Old Jan 14, 2013 | 07:23 PM
the_frozen_one
It's unlikely, a fault with the above would cause a running issue, not just a power loss. you could send the injectors away for testing and cleaning or buy new ones but i doubt it would make much difference. a fuel filter change would be worth a shot for the few quid it costs, but i'd stake my money on a worn cam
Old Jan 14, 2013 | 07:26 PM
chrisgcombi
apparently its had a kent cam not so long ago
Old Jan 14, 2013 | 07:28 PM
chrisgcombi
weres the fuel filter located , is it easy to replace , thanks
Old Jan 19, 2013 | 08:21 PM
mattxr3i's Avatar
mattxr3i
Get it on a rolling road and see what it's doing, they will be able to see what the fuel mixture is doing all through the rev range too.
Has the cam been timed up properly as they are very sensitive to Cam timing
Old Jan 20, 2013 | 06:07 AM
Fordmad!'s Avatar
Fordmad!
Efi or mfi? If its efi the fuel filter is on the right as you look in the bay, its the shape of a coke can but slightly bigger!
Id take the rocker cover and check the cam. They do suffer badly from worn cams etc
I ve just spent Ł500 on mine complete top end rebuild as it was knackered!
Old Jan 20, 2013 | 10:37 AM
chrisgcombi
Thanks for your reply appreciated , i will check it out thanks
Old Feb 11, 2013 | 11:32 AM
s6boy1979's Avatar
s6boy1979
Find out when the cam was done as the cam wear is crazy on the 3i's, mainly on cyclinder 4. Had mine RR and was expecting about 130bhp as it has a filter, 4 branch straight through and chip but only made 81bhp but they said this was due to a flat cam, They come out the factory at 105bhp lol
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
