Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
mk5 escort heater only blowing cold air
Old 29-09-2012, 11:20 AM
Lee Philip
Lee Philip's Avatar
Default mk5 escort heater only blowing cold air
hi my mk 5 xr3i heater is only blowing cold air i have been told that if its the heater matrix its a big job :s i am hoping someone will have an idea if it can be fixed easily or not cheers
Old 29-09-2012, 07:08 PM
JOHNDQ
JOHNDQ's Avatar
If they told you that they having you on mate takes 20 mins to get dash out, remove steering colum, two muti plugs from top of fuse box and speedo cable from gearbox everything comes out still bolted to dash.... simples
Old 26-11-2012, 05:13 PM
Archer14
Archer14's Avatar
one of three things
1. heaters control valve is stuck. this doesn't allow it to switch over to 'heat'.
2. there is blockage in the heaters core, not enabling fluid circulation thru it, thus not supplying warm to the cab
3. the temperature is stuck open. thus the coolant is constantly flowing and does not have a time to heat up the way it should for heaters use
i would check the control device first. wish this helps ya
Old 28-11-2012, 08:03 AM
Moderator
STeve's Avatar
check things like thermostat first before ripping things apart and what was mentioned above, matrix is a sh1tty job at best of times
Old 19-11-2013, 02:02 PM
Diesel combi pete
Diesel combi pete's Avatar
Originally Posted by Archer14
one of three things
Where do you say this heater valve is, as I did not think there was anything like that on the mk5, just a flap to change the flow of the air through the heater matrix, My heater at the moment is playing up cold also. help would be great as I have cleand out the matrix and it is clear cheers, Pete
Old 19-11-2013, 05:18 PM
JOHNDQ
JOHNDQ's Avatar
defo no elec's in the MK5 make got a heater box sitting in garage its just cables. Are they moving the arms on the heater box when you move the controls
Old 19-11-2013, 07:36 PM
Diesel combi pete
Default re...
Yes, when I move the control I get the luke warm air then in the cold possition I get dead cold air, so the controls are working. I have never came across anything like it. The two pipes going into the matrix are hot but when I turn on fan the heat is slightly hot for a short time then luke warm again as if there is not a constant or fast enought suply, Thermastate is deffinatly ok..
Weather getting colder I had to wear gloves last Friday,
Cheers, Pete
Old 20-11-2013, 05:26 PM
JOHNDQ
JOHNDQ's Avatar
if the heater rad/pipe work is ok you sure you haven't got a damaged water pump
Old 20-11-2013, 07:24 PM
Diesel combi pete
It dose seem like there is not any flow, I will have to check it. I will take the out pipe off the matrix and run the engine and see if I am getting any feed out if not I am due to do the timing belts oil and so on soon, so could change the pump at the same time if need be.
I brought the van on ebay, it went streight through the mot, i then turned it into small stealth camper can be seen on my youtube site, >pepersorte< I have this last five months in our sumer done 11,000 miles, not had a thing go wrong never touched to water at all till this week, so I cannot moan. Getting 61 to the gallon on a ru. I will let you know the outcome. Cheers, Pete
Vincereese
01-06-2023 09:14 AM
Kyle Langford
27
05-08-2019 07:54 PM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Quick Reply: mk5 escort heater only blowing cold air
